Did the original steel head studs not have any form of protective coating? I cleaned the ones I pulled off our engine. Didn't appear to be plated. Within a couple hours some surface rust started to form. I brushed it off and lightly coated them in oil for the time being. Not sure what the long term solution should be.
Not sure about the original ones but I’ve bought new head studs for my 2.7, 3.0 and 3.2 and they are coated.
Original Porsche studs are non coated steel.
Bruce Sorry for the original misprint Last edited by Flat6pac; 01-04-2024 at 03:33 PM.. |
PCA Member since 1988
You didn’t say what engine. Original Steel studs usually have a back oxide coating. I like to paint them anyway. Although I haven’t personally seen broken steel studs, they do break. corrosion can cause stress concentration and cracking, so I figure a coat of engine paint can’t hurt and should help. .
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
It's a 914 ...
I've seen early steel studs that at a casual glance appeared to be bare steel. That may well be wrong, perhaps they were oxide coated at PeteKz suggests. Or maybe the coating was worn off.
I think our case through bolts are bare steel. |
It's a 914 ...
Thru bolts are bare metal, yes
They all looked surface rusty to me, to various degrees.
Try not, Do or Do not
I love threads about head studs.
Simply put, early steel studs were heat treated before thread rolled. Hence the black appearance. The next iteration of head stud was the gen 1 Dilavar. It was cad plated silver. If they were not baked after plating, they could have suffered from nitrogen embrittlement. These studs were prone to breaking so Porsche decided the produce the same stud (cad plated) but added a coating of black epoxy. They still broke so for a short time they went back to the ht plain steel. Because of ensuing warranty issues they decided to try a new design Dilavar stud. This new monstrosity was an all thread/cad plated, epoxy coated stud, this one incapable of creating a truly stable head the cylinder connection. When they ended the air cooled engine, all head studs were returned to a more predictable steel alloy (all be it, heinous all thread), even in the Mezger engines like twin turbos and GT3.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 01-06-2024 at 04:48 PM.. |
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
