Originally Posted by Bill Verburg View Post
Any progress?
Not much to update, waiting on some wiring harness pieces. My mechanic is going to install a connector in the main harness to separate the harness without disconnecting everything on the engine or body side of the car.
The body harness, wideband 02 sensors and the exhaust cutoff wiring has all been routed through the tunnel.
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 02-13-2024, 08:28 PM
Bill Verburg's Avatar
so the harness is in the tunnel?
usually that big hole in the bilk head to the right of the harness is where it would come through
can't wait to see it installed
I've started collecting the pieces to mount mine like that
got the 3.2 console
will use the Sheridan f/g tin replacements
debating whether to go for a Ti or SS cross bar, I like the Rennline version because of the boxed ends but Ti would be nice too
Bill Verburg
Old 02-14-2024, 10:51 AM
got the 3.2 console
Yep, the harness will still go there, just simplified and cleaned up.
I would like to do a different cross bar, I dislike the one I currently have, I just don’t really know wha5 will bolt on vs having to make something.
The Sheridan parts look even better in
Person, I highly recommend them.
I have no before pics, but the old harness was a hack job, chaotically finished in green electrical tape. This setup is so much cleaner with a main harness quick release.
2017 Macan S
Old 03-07-2024, 07:55 PM
Work has been hectic, but I was able to get a free day to start the install. Got a bunch of odds & ends finished up, and the engine is now mounted. I need a few more hours before we are ready to fire but we are getting close
2017 Macan S
Old 03-31-2024, 09:03 AM
I'm going to pull mine this week to correct a few other issues and replace the tin w/ Sheridan f/g, also bought a Rennline cross bar & mounts
Bill Verburg
Old 03-31-2024, 04:21 PM
Shorter studs are needed for the 3.2 console vs the 3.6 version
Bill Verburg
Old 04-03-2024, 12:18 PM
Engine is back in the 99 3nvr fits like a glove
Heat needs to be re imagined though
Bill Verburg
Old 04-05-2024, 09:44 AM
Bill, where did you get that crank pulley ? I need one...
BTW- looks great.
'77 1973 911RS Backdate, 2.7 liter w/webers
'70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress
'75 911 RSR street car in progress
'77 930 Replica '75 993 GT2 EVO race car , 3.6 TT
'79 928 5 speed money pit in progress
Old 04-05-2024, 11:54 AM
BTW- looks great.
It is a 993 RS single sheave
part #s are
993-106-051-80 impeller hub for the alternator
993-102-050-40 pulley for the crankshaft
Bill Verburg
Old 04-05-2024, 04:14 PM
Got the car started over the weekend
Exhaust was on quiet mode and the fan needed adjustment in the first video.
https://youtube.com/shorts/0eUl2jDfAyM?si=BgfGs_K991Aupg8R
https://youtube.com/shorts/htasQ4l5LP8?feature=shared
2017 Macan S
Old 04-08-2024, 10:31 PM
I'm enjoying following your build, and you are inspiring me to do a 3.6 swap into my 911SC. I have found a US Spec 993 3.6 VRAM, but worried about the pain I've heard the OBD2 system causes. Any words of wisdom or recommendations on how you dealt with the OBD2 system? Thanks
Old 04-09-2024, 12:12 PM
Hey Bill!!
I wish I had more input for you. The engine mount came with the engine when I bought it years ago, at the time it bolted up so I didn’t give it much thought. I’m not a big fam of how my setup looks and I’m considering replacing it with something else.
Can I sent you an in depth video next time I’m around the engine so you can get a better view of it? Maybe some extra pictures?
After looking at these things for the past 2 years , I Think that you are using the 993 console and crossbar
Sheridan told me emphatically that his f/g wouldn't work w/ that combo but you prove him mistaken
The f/g must allow the engine to sit higher than mine w/ the 3.6 tin did
after replacing the 3.6 console and cross bar w/ 3.2 version the engine sits where a 911 engine should, the rubber along the sides seals and more importantly the exhaust is tucked up where it should be
I'm pretty sure the these are the pieces you have
these are the pieces I used
down side is
1) I had to redo the heat, not an issue on yours
2) the stock air cleaner box just won't fit so I went back to the cone I used a few years ago.
Bill Verburg
Old 04-09-2024, 02:43 PM
That’s awesome!!! The 3.6 is a nice upgrade on the older cars.
I had the same concerns as you and decided to go with the 95 obd1 engine and retrofitted the VRam intake after the fact. I think the later cars can be done, but I didn’t want that extra challenge.
2017 Macan S
Old 04-10-2024, 09:26 PM
Who made your wiring harness? Mine is all hacked up, so I need a clean one like you have.
Old 04-18-2024, 12:08 PM
Same person that did my engine. That said, for the cost it's probably worth the extra cost to just have a mil-spec harness made.
2017 Macan S
Old 04-22-2024, 08:17 AM
Happen to know of anyone making mil spec harnesses for a 3.6 to SC swap?
Old 04-22-2024, 09:31 PM
Rasant and Ry-wire should be able to help.
2017 Macan S
Old 04-23-2024, 09:51 AM
Well, i finally made it through the break in miles and got to do a few pulls on the Dyno.
Here are the baseline pulls with a few things to note.
- I have a fuel cutoff from the SWchip at 6,200 RPM, I may be able to squeeze a bit more going up to the factory 6,800-7,000 redline
- it looks like my AFRs are a bit on the lean side and that will need to be adjusted for safety, maybe HP?
- I'm in Colorado at 5,280 ft elevation (i don't know if that really changes anything?)
- The last pull (in orange) was with the "quiet" mode selected on the GT3 muffler. I was expecting a bit more loss there.
i assume with some changes to the chip and AFRs i should be able to get a few spare ponies out of the car. at 268 Wheel Horsepower i assume I'm making around 310 crank, which puts me in the range of what i would say is reasonable.
Here is the build.
Mahle 3.8 liter piston and cylinder 11.4:1 compression
993 RS Intake Valves
993 RS Exhaust Valves
Light Port and Polish
Pauter Lightweight Connecting Rods
AASCO Titanium valve springs retainers
AASCO Titanium Retainers
AASCO Titanium Keepers
FVD Mechanical Rocker Arm Conversion
FVD Sport Cams for Mechanical Rocker Arms
Fabspeed Carrera Cup Intake
S-Car-GO 1 7/8 Headers
Gt3 muffler (top and bottom feed)
Steve Wong Chip
Arp hardware
Patrick Motorsports Light Flywheel
Patrick Motorsports 3.6 conversion Clutch
Rothsport Single Belt pulley
Any thoughts or feedback?
DYNO VIDEO
https://youtu.be/ikdKA20s9oM?si=O4aztkx34I4ATpbL
2017 Macan S
Old 12-20-2024, 12:31 PM
PCA Member since 1988
Since you are in Colorado, did the dyno operator correct for altitude? Typically a non-boosted engine loses about 3% HP per 1000ft, thus you would be down about 15% compared to sea level. If those were not corrected for altitude, then you have even more power at lower altitude than you measured.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-21-2024, 01:14 AM
Racer
winders's Avatar
For the SAE correction, the Dynojet software corrects to 77 degrees F, 29.23 inhg and 0% humidity. At least they used to do that.
Also, I believe that dyno sheet is stating it is using SAE correction and that the correction factor used on the raw data is 1.19. So that 267.42 HP pull measured at 224.72 HP.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 12-21-2024, 04:00 AM
