WYDBODY1986's Avatar
Flushing or blowing out cooler lines after rebuild
Hi Guys,
I did a short search on this topic but really didn’t find anything. I’ve finished rebuilding my engine and I am in the process of installing it in the car. The engine was rebuilt due to bad valve guides, everything else was fine. No failures. It has been about a year since the engine was pulled and I did wrap up the oil lines to the thermostat with a plastic bag on the end of them so I am wondering if I should flush or blow out those lines and the lines from the thermostat to the front cooler Knowing how incredibly hard it is to break the nuts loose on these. Is it safe to leave them be knowing I will change the oil a few times in a short period?
TIA,
Brian
Old 01-12-2024, 11:20 AM
PCA Member since 1988
Don't worry about it. The oil return goes through the filter, then into the tank. It's the supply side you have to be anal about.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-12-2024, 12:28 PM
Chain fence eating turbo
Always wanted to do this myself.
I believe you simply heat the thermostat on the passenger side rear tire area (at least on a Carrera 3.2) to get the T-stat open, then flush from there.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-15-2024, 01:00 PM
Thanks for the replies guys!
Old 01-15-2024, 02:22 PM
