I can’t recall where this goes
Currently rebuilding engine. I plated a bunch of parts. I can’t recall this coming off my engine (3.0). Any ideas? 8mm nut for reference.
Old 02-04-2024, 04:44 PM
I looks like it would go on the end of the crank pulley, it does nest in there, but the bolt is too short and there is no reason for it.
Old 02-04-2024, 05:04 PM
Mystery Washer/s…………
There are two (2) of these washers in your motor! CLUE : Left side and right side.
Tony
Old 02-04-2024, 06:06 PM
Thanks, I have a few parts to do with the valve train that I have yet to comb through. It’s mate should find its way to the surface.
Old 02-04-2024, 08:30 PM
PCA Member since 1988
Washers for cam bolts, if your cam has bolts instead of big nuts?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-04-2024, 11:39 PM
Petez, very late 1983, in fact it is a 3.2 case. Big bolts, not big nuts.
Old 02-05-2024, 12:12 PM
Do they fit the cam bolts? And cover the pin that goes into the timing sprockets? If so, there's your answer.
Old 02-05-2024, 05:26 PM
I only have the one engine. Not like your arsenal of engines pete.
Old 02-05-2024, 07:04 PM
I do have a spare laying around...
Old 02-05-2024, 11:51 PM
Thank pete, I found it with the other bolt, sprocket s and followers that i’m changing out.
Old 02-08-2024, 07:00 PM
I must have learnt alot from these thread , thanks buddy
Old 02-08-2024, 07:07 PM
Are you a troll?
Old 02-08-2024, 07:11 PM
