Intermediate shaft surface question
I am cleaning up parts for a guy to build my 2.0 engine. Today I did intermediate shaft and two bearing surfaces appear to be a little marred. Part has the look but doesn’t snag my finger nail. Have not asked him but trying to anticipate what needs to be done.
Thanks for input.
TOT
Old 02-04-2024, 07:18 PM
Have it polished like they do to a crankshaft.
Old 02-05-2024, 12:14 PM
Additional question
Silly questions
1. Do gears need to be removed for polishing shaft?
2. Typical cost to polish ?
TOT
Old 02-08-2024, 08:25 AM
Originally Posted by zztot View Post
Silly questions
The shaft in your pictures doesn’t look great. My new intermediate shaft bearing diameters were about the same as my old shaft. I bought a IS complete with gears which was special order and no returns. I might have been ok by just replacing the one chipped aluminum gear.
I think the gears could stay on, providing it is washed well after polishing. I’m not sure on the cost for this, but it couldn’t be much. My crankshaft was $90 to remove oil galley plugs and polish.
Old 02-08-2024, 10:03 AM
It's a 914 ...
stownsen914's Avatar
Take a good look at the aluminum gear teeth. They can be pitted as an early indicator it's time for replacement. You don't want one of those failing.
I ask because if you are removing that anyway, at least one of the small gears comes off too if memory serves.
Old 02-08-2024, 01:55 PM
More
Gears appear to be pretty nice…….but not shaft.
Appreciate the input.
TOT
Old 02-08-2024, 02:16 PM
Try buffing it out with a red/maroon scotch brite pad. Or start with a gray pad if you want to be a little less agressive...
Ward Komers
1984 944 Track Car - Sold
1968 912 Rust Bucket - Under Repair
1971 911T - Under Repair
2006 Carrera S - Sold
Old 02-08-2024, 03:34 PM
Have it cleaned and polished like they do to a normal crank shaft pulley
Old 02-08-2024, 07:10 PM
