Engine tin?
Okay so my car is only driven on the track. A few years ago I had a company help straighten everything out for the track. When it came back it had no engine tin on it. Guy said it didn’t need it because it’s a track car only, so what do you guys think should I find new tin or fiberglass and put it back in?
gee... I would have wanted it fitted, or at the least, wanted it given back to me.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
The engine tin is the only thing that separates cool air coming into the intake and cooling fan, or recycling hot air from cooling the engine back into the intake and engine cooling. I would insist on getting my tin back.
a Find a different fellow to wrench for you.
Try not, Do or Do not
Choice of material is personal preference.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I remember years ago there was a race shop (name escapes me) that build all their race cars with no tin..... It was their thing. Never made sense to me.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
PCA Member since 1988
If you're always between 50MPH and 150MPH, I expect you're getting enough fresh airflow back there.
I'd want to use the tin anyway.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
^^^lol, Ya, like I said the name escapes me, but they build and supported plenty of cars back then.
Cheers
