3.3 recommended piston ring gaps
I got a low miles used 3.3 p&c set that are well with in the installation specs, Im using a set of new Mahle piston rings with them and right out of the box they all measured .016 for both top and 2nd rings, is that OK for a boosted 3.3? .. I'm planning to get close to 1 bar with that engine. Also since I'm using new rings, would you recommend de-glazing the cylinders with something like 400 or 600 grit?
Deglaze with scotch brite and water with your hand.
600 grit is too coarse. Bruce |
Constitutional Liberal
.016" is too small. I use the formula .006"x bore. .006"x 3.8"=.0228" + or - .001 Basically .021 to .023" The second ring should be .002" larger than the top ring. This allows the pressure that passes the top ring to escape unimpeded. If the second ring traps the compression, this will create pressure under the top ring that will damage the piston/ring land.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
So is it safe to go with .020" for the first and .022" for 2nd? .. I just took my 3.2 apart and all rings were at .016" so I guess the turbo engines needs a bit more gap to be safe, right?
I'm glad that you read my post, Henry, I really need your opinion here before I do a costly mistake, do I really have to throw away the Mahle rings and get Goetzes? .. I'm not looking to get 500+whp, just want a decent power out of a 3.3.
I think Jim was speaking to other builders looking to buy new rings. He didn't tell you to throw away your rings. I really like the Goetze old school ring. I think it's an "old dog...new tricks" deal. I even have custom pistons designed to utilize Goetze ring and you wouldn't believe the push-back I get from piston manufacturers.
Happy to hear that
.. thanks Henry
Do you size naturally aspirated rings differently than turbocharged?
NA engines don't need as much ring gap. If it's boosted, you'll need to add another 0.001" or so for each inch of bore because of the higher combustion temperatures.
As we used to say... Big ring gap = big catch can Small ring gap = big trash can |
Chain fence eating turbo
I run my gaps looooooose now as I had them too tight during 1st rebuild and tore up the Nikasil and Total Seal rings.
Very costly mistake!! No blowby after refresh. |
could you please share your before/after end gaps? .. I care of knowing about some real-time tests.
I’d like to know too. I assume Total Seal rings have a different spec if they’re gap-less ones but maybe they make standard ones too?
Ken 1986 930 2016 R1200RS |
What are the differences between the standard ring Mahle uses and the Goetze rings?
The difference would be design, materials and coatings. My guess, Goetze has proprietary processes. I still believe that quality exists inexperience, and reputations are built on quality.
