Engine tin?
Okay so my car is only driven on the track. A few years ago I had a company help straighten everything out for the track. When it came back it had no engine tin on it. Guy said it didn’t need it because it’s a track car only, so what do you guys think should I find new tin or fiberglass and put it back in?
Old 02-28-2024, 10:22 AM
gee... I would have wanted it fitted, or at the least, wanted it given back to me.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 02-28-2024, 11:07 AM
The engine tin is the only thing that separates cool air coming into the intake and cooling fan, or recycling hot air from cooling the engine back into the intake and engine cooling. I would insist on getting my tin back.
Old 02-28-2024, 11:35 AM
a Find a different fellow to wrench for you.
Old 02-28-2024, 12:27 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Engine perimeter tin is necessary to promote proper cylinder and head cooling cooling. This tin also reduces the ingestion of hot into the air intake.
Choice of material is personal preference.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-28-2024, 04:58 PM
Jeff Alton's Avatar
I remember years ago there was a race shop (name escapes me) that build all their race cars with no tin..... It was their thing. Never made sense to me.
Cheers
www.turn3autosport.com
Old 02-28-2024, 09:02 PM
PCA Member since 1988
If you're always between 50MPH and 150MPH, I expect you're getting enough fresh airflow back there.
I'd want to use the tin anyway.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-28-2024, 11:19 PM
sounds about right, and wheres my "left over parts?"
Old 03-08-2024, 12:05 PM
Cheers
Did any of their cars finish a race?
Old 03-08-2024, 12:06 PM
Jeff Alton's Avatar
^^^lol, Ya, like I said the name escapes me, but they build and supported plenty of cars back then.
Cheers
Old 03-08-2024, 02:44 PM
