valve guide seals
There's a lot of experience on this site and I would like to tap some of it. About to assemble my 1971 911T heads. I have the still in package white valve stem seals
from a Reinz gasket set purchased about 40 years ago. Opinions on whether to use them or is there a better seal available? Thanks Pelicans
Old 04-07-2024, 02:26 PM
I use the white ones. The brown ones are harder to install and can sit cockeyed or be damaged on installation. My 2¢.
206 637 4071
Old 04-07-2024, 04:18 PM
appreciate your input John, thank you.
Old 04-13-2024, 02:49 PM
Try not, Do or Do not
Henry Schmidt's Avatar
A couple of quick notes:
Viton vs Teflon
The Viton are a little more sensitive to install if you don't have the proper tool.
Teflon is no issue.
The Viton seal will work better to control the oil to the valve stem.
Here's the stoss up.
Less oil to the guide means shorter life.
The valve stem likes oil.
Now, more oil means more smoke, generally a puff or two at start up.
Most racing engines of old didn't use any seal on the exhaust valve.
For us it's an "old dog new tricks" issue. We have used the Teflon for 40+ years.
A puff of smoke just tells me everything is being lubricated.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-15-2024, 09:25 AM
SalParadise's Avatar
Viton vs Teflon
Teflon is no issue.
Awesome quote Henry. One for the books.
Old 04-23-2024, 03:13 PM
Discseven's Avatar
Duff... not sure if it's applicable to '71 seals but there are thin collars that fit onto a valve stem's end that protects the seal as it is being installed.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 04-28-2024, 05:45 AM
