rebuild complete- starting and power issues
3.2 rebuild is done- runs very smoothly, but..... - 2 issues
1. cold start now takes forever!- before rebuild, was instant start- i changed nothing in injection or intake system!- just lifted off and re-installed- warm start is perfect, just like before 2. am not getting nearly as much power on acceleration out of engine as i should be- it is smooth enough, and revs fine, but not what we all know we should feel any ideas?- connection between the two?- how to diagnose? thanks!! |
It could be the temperature sensor. I also believe at some point Porsche changed the sensor from one wire to 2 wire to improve grounding.
Resistance test varies with temperature.
Ed 1973.5 T |
Administrator
Pretty common for throttle cable to be out of adjustment after an engine R&R |
And any other thought as to why no temp display at gauge? Thx! |
Cutting and splicing the wire for head temp will change the resistance which is what is being measured by the ECU. Since the single wire uses engine ground for the ground side you should check that you have good engine grounding as well. You should replace the cylinder head temp sensor since the wire has been cut.
The temp gauge uses a different sensor so different problem. Gauge is easy to trouble shoot and plenty of threads on how to do if you search. john |
I can't say that is your problem, but it should be done. Porsche switched to a 2 wire sensor because of issues with the single wire unit. I would definitely want to change one with a splice.
It is a bit difficult due to the sensors location and the wires attached to it. The socket needs to be a deep one with a slit in it for the wires, and another thing was the new sensor uses a different size socket than the old single wire sensor. ![]() Other things to check besides possible air leaks is to make sure the throttle linkage, full throttle switch, and idle switch on the throttle body are set correctly. One other thing I read about is a brown wire by the DME under the seat. It is for California emissions. It should be unplugged, except on cars that have to be smogged in California.
Ed 1973.5 T |
what did you set the camshaft timing to?--for your power loss problem..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 05-07-2024 at 12:07 AM.. |
