Weird rod bolt interference
I am having 2 liter 6 built. Most likely unneeded ARP rod bolts were. Everything went together but on very last cylinder (#5) something interfered with rotation. It turned out to be a rod bolt projecting further than all others once torqued….. like 3+ or so threads.
It hit the bottom edge of the cylinder . Once it had a few thousands ground off everything cleared and it rotates freely. Question……WTF? Seriously what’s going on? Kind of spooked so looking for explanation… Any ideas??? Thanks
TOT |
PCA Member since 1988
Strange. The ARP bolts should all be the same length. Pull that rod and measure the bolts. ARP provides a spec for bolt length.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
If it’s not the bolt, my guess would be it’s got to be that rod, rod bearing or crank journal.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
It's a 914 ...
Any chance you got one 2.2-2.7 rod bolt in your set? They're similar but longer. 2.0L rod caps are shaped differently than 2.2-2.7 rods so have a shorter bolt.
Try not, Do or Do not
Good thought but the 2.2 (70-71) and 2.4/2.7& 3.0 (72-83) bolts are different. ARP never made a rod bolt for the 2.2 rod. The 70-71 rod was unique to the 2.2 and ARP never saw a big enough market to make a bolt to fit that rod.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
It's a 914 ...
Ah gotcha, makes sense.
I'd want to pull the bolts out of the #5 rod and see what's different about the offending bolt. For example, since it's obviously different, maybe the widened shoulder in the middle of the bolt is different too. Could just be a bolt that's meant for some other application but got mixed in with OP's set for whatever reason. |
Response
ARP has tech assistance on line. they feel incorrect bolt was packed based on dimension.
Sending me a new one.
TOT |
You definitely need more than a few thousands clearance in there.
Andy Brian |
Resolution
So appears as though we have a satisfactory resolution.
I contacted ARP through their online helpline and explained the issue. Very quickly they told me wrong bolt length apparently got packed with set. A new bolt was sent overnight. Here’s the best part………once installed and torqued, only one thread was showing just like all of the others and unlike the three or so that were showing on the other bolt. Dimension was not off as far as originally reported but something definitely not right. Thanks for the input.
TOT Last edited by zztot; 07-26-2024 at 07:56 PM.. |
Henry question
So one more question Henry.
Based on issue wanting to confirm (for builder) that .5mm/.020 clearance between rod bolt and base of cylinder is adequate? Thank you
TOT |
If the rod gets loose enough or swings wide enough to take up .020" of clearance, you will have much bigger problems.
Response
Pete:
I believe (with my limited knowledge) that to be true…….The question was asked of me but could be bc I rely on this forum for input on the build to keep us in current good practice. Thanks to all for continuing help in keeping me out of the woods.
TOT |
