Try not, Do or Do not
Piston fun....enjoy
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
PCA Member since 1988
Yup, saw that a couple weeks ago. Crazy how much R&D goes into those aluminum pots. But I think that is an area where racing actually does improve the manufacture of street cars.
As Henry and others know, the thinner rings in a higher and tighter stack have lower drag in the cylinders, better sealing, and less quenched space between the combustion chamber and the top ring. Those were first developed for racing purposes, then were adopted for street engines, where manufacturers have to work hard for every little bit of improvement in efficiency and lower emissions.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I remember reading a few years ago that Ferrari were experimenting with 3D printed pistons, the advantage of which was the ability to create internal voids to reduce weight.
If I understand it right Porsche uses "3d-printed" pistons in the GT2 RS since 2020. Lower weight and improved cooling with oil channels in the piston.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Sent from my SM-G991U using Tapatalk |
thanks for the post!
