Try not, Do or Do not
Henry Schmidt's Avatar
Piston fun....enjoy
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-12-2024, 09:35 AM
PCA Member since 1988
Yup, saw that a couple weeks ago. Crazy how much R&D goes into those aluminum pots. But I think that is an area where racing actually does improve the manufacture of street cars.
As Henry and others know, the thinner rings in a higher and tighter stack have lower drag in the cylinders, better sealing, and less quenched space between the combustion chamber and the top ring. Those were first developed for racing purposes, then were adopted for street engines, where manufacturers have to work hard for every little bit of improvement in efficiency and lower emissions.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-12-2024, 02:31 PM
I remember reading a few years ago that Ferrari were experimenting with 3D printed pistons, the advantage of which was the ability to create internal voids to reduce weight.
Old 09-12-2024, 07:29 PM
safe's Avatar
If I understand it right Porsche uses "3d-printed" pistons in the GT2 RS since 2020. Lower weight and improved cooling with oil channels in the piston.
Magnus
Old 09-13-2024, 09:05 AM
They did test 3d-printed pistons in the GT2RS but I'd don't think they came on the production cars. I think it was more of an R&D exercise at the time.
Sent from my SM-G991U using Tapatalk
Old 09-13-2024, 10:23 AM
thanks for the post!
Old 09-22-2024, 09:54 AM
