Axel84's Avatar
996 GT3 Rods in a SC engine
Do these fit in a SC engine? or do you need a GT3 crank also?
thank you
My worst fear is that when I die, my wife will sell my cars for what I told her I paid for them
Old 10-01-2024, 01:35 AM
Here’s a table to get good info
https://pauter.com/parts/rods/porsche/
Old 10-01-2024, 04:28 AM
Old 10-01-2024, 04:45 AM
Old 10-01-2024, 04:47 AM
Try not, Do or Do not
Henry Schmidt's Avatar
There are a couple of generations of GT3 rods. The basic answer is, yes. The 996 GT3
rods will fit the crank. Early rods are 127.8mm and later 996 rods are 130mm.
These rods make for a nice replacement for high rpm builds.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-01-2024, 06:44 AM
Axel84's Avatar
Ok so a direct fit to a sc crank or?
Old 10-02-2024, 09:18 AM
Big end diameter:
- 3,0L is 56,01 mm.
- GT3 is 56,02 mm.
Maybe make sure if other bearings are needed ?
Old 10-02-2024, 09:58 AM
It's a 914 ...
stownsen914's Avatar
Interesting. .01 mm is .0004” if I’m doing my math right. That should be within the range to address by resizing the BE of the rod.
Old 10-03-2024, 07:39 AM
Administrator
I assume the Ti Pankl GT3 rods don't fit a 993 crank? Dimensions look really close but maybe not close enough.
Old 10-05-2024, 04:28 PM
def not
Always learning.
www.aircooledporsches.com.au
Old 10-05-2024, 09:41 PM
Correct.
And considering there is a range of bearings you can buy, some are made with extra clearance etc..
Like any build, it will be at the discretion of the machinist and the builder, their measuring equipment and how well they use these tools.
Others on this forum remind me that GT3 ran slightly larger clearance at times.
Always learning.
Old 10-05-2024, 09:42 PM
