Engine rebuild
I’m at the point where I need to rebuild my 3.0 original engine. I’m considering the options. Since I’m looking at sinking so much $$ into a rebuild I’m considering all options. Who has experience buying 3.2 engines? Is there a resource for finding one or am I just going to be hunting and cruising eBay? Thanks in advance for advice on whether to swap or not, and if so, how, and what becomes of the original engine? Should I keep it or sell it to offset cost of a 3.2. I’m inclined to keep it original personally.
Drive it like u stole it.
Zacha,
Welcome to the board. Post some pics of your project to show you are legit (we get a lot of scammers on here). Give us some more details of what you are working with like Year, give us the engine number (should be on the case on the right side of the fan up top). Are you thinking about a DIY build or looking for a builder? This board can help steer you either way. Where are you located? Bill
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
2 cents
Start with ….. Building original engine will maintain cars value…..Its up to you whether or not that is a consideration, but once gone you don’t get a do over!
TOT |
PCA Member since 1988
In addition to the others' comments: Why do you think it needs a rebuild? Serious question. The 3.0 engines are very durable and can log 300,000+ miles. It's common to do a valve and guide refresh in the mid-100Kmi range, but not a full rebuild (even though people think they need to).
As for your budget for a full rebuild, $$ ain't enough, you need $$$$. Ditto for a 3.2 swap. If swapping to a Carrera 3.2, do you plan to keep the original CIS fuel injection or swap over the complete 3.2 Motronic file injection? And post pics.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Where do you live?
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Rebuilding your 3.0 engine vs. swapping for a 3.2 depends on your goals. If keeping originality matters, rebuild the 3.0. For a 3.2 engine, look at specialized Porsche parts dealers, forums, or classifieds for options. Keep the original for value or resale, or sell it to offset costs. I was struggling with a complex research topic and decided to use https://academized.com/write-my-research-paper to help me out. The writer assigned to me was an expert in the subject and delivered a high-quality paper. It was well-researched, plagiarism-free, and met all my professor’s expectations. The customer support team was also very responsive. I couldn’t be happier with their service!
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
If you want a 3.2 just replace the P+Cs and have a nice SS 3.2
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
+1....3.2ss
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Open Highway Productions
If you are in a rush to get it done;
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1170072-rebuilt-3-2-carrera-engine-sale.html The price is discounted...
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
If you are serious about a replacement engine, contact "Mepstein" here on Pelican. He is a solid seller and stands behind his sales. Sells a lot of engines; here is one currently for sale:
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1170072-rebuilt-3-2-carrera-engine-sale.html (Same as posted above) I would buy an engine from him without worry. I have bought other parts from him and he is the best. Cheers, Michael
'71 914-6 #0372 '17 Macan GTS |
Banned
Building original engine maintain cars value
