0 or 1 Crank code for backlash measurement
Hi,
While measuring backlash I found the codes on my case, on my intermediate shaft gear but I can not find the 1 or 0 on my crank gear……
Anyone can give me a clue where to find it!?
Merry Christmas!
Cheers,
Bart
Old 12-25-2024, 07:59 AM
Mix and match crank and intermediate shaft gears to get results, sometimes “0” intermediate shaft gear works best in “1” case. Sometimes gears aren’t marked.
Old 12-25-2024, 11:04 AM
Thans for quick reply!
For sure I do not see these ‘writen’ numbers….
Was expecting a similar indention like in case and aluminium intermediate shaft gear.
The tolerances are depending on the coding of the three, will see now if I end somewhere inthe middle ;-)
Old 12-25-2024, 03:18 PM
From my limited experience, the crank gear is generally not marked. The engine case is marked.
Case is marked. IMS gear is marked.
Bentley manual has a mix and match table.
Old 12-29-2024, 08:45 AM
targa72e's Avatar
Mix and match gear chart referenced above.
john
Old 12-29-2024, 11:19 AM
Thank you gents!
So not knowing what the crank gear code is I will aim for 0.03-0.042 to be safe.
Cheers,
Bart
Old 12-31-2024, 04:14 AM
Try not, Do or Do not
Henry Schmidt's Avatar
When considering the intermediate gear backlash the crank gear is generally a non-issue.
The crank and crank gear are precision machined to a much closer tolerance the the case.
Check you backlash keeping in mind that when a magnesium case heats, the inconsistent expansion provides for ever changing clearances.
The 964 gears are numbered/matched because the gears are both steel and prone to high harmonic vibrations. They match the gears on a machine that checks vibration at operating speeds.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-31-2024, 07:04 AM
Thanks Henry!
Always good if someone put things back in perspective ��
Old 12-31-2024, 10:45 AM
