Senior Member
Ssi heat exchanger bottom mounting points
What’s the best procedure for attaching heat exchangers to an SC. One hole where the mounting tab goes had a tiny shallow set screw maybe 6mm and not too deep. Are you guys drilling these out larger and tapping or using as is or ??? Thanks.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Senior Member
Guess I don’t need them seems like they wouldn’t do much anyway.
The studs for the tabs were originally 6mm .
