i never use old chains.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 08-01-2025, 12:13 AM
The 9 Store
Right! Chains and plastic chain guides are consumables. If sprockets are getting pointy, they get replaced.
All used parts sold as is.
Old 08-01-2025, 04:30 AM
Jesse911's Avatar
I will be buying a new oil pump. I narrowed it down to two options:
3.2 pump
993 pump (aluminium)
The 993 pump being bigger should provide more oil. Apart from the shorter shaft do I need to make any other changes?
Jesse
'76 911 backdate with Carrera 3.0 engine
Old 08-14-2025, 01:49 AM
Jesse911's Avatar
Some updates:
Checked big and small end on the connecting rods. Bought this tool online and had a friendn print it with his 3D printer. Works really well.
Went with the 993 oil pump, fits the Carrera 3.0 (930/02) case without mods!
My KMS ITBs
Now onto setting end gaps for the pistons rings.
Jesse
Old 09-01-2025, 03:52 AM
