i never use old chains.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
The 9 Store
Right! Chains and plastic chain guides are consumables. If sprockets are getting pointy, they get replaced.
All used parts sold as is. |
I will be buying a new oil pump. I narrowed it down to two options:
3.2 pump 993 pump (aluminium) The 993 pump being bigger should provide more oil. Apart from the shorter shaft do I need to make any other changes?
Jesse '76 911 backdate with Carrera 3.0 engine |
Some updates:
Checked big and small end on the connecting rods. Bought this tool online and had a friendn print it with his 3D printer. Works really well. ![]() Went with the 993 oil pump, fits the Carrera 3.0 (930/02) case without mods! ![]() My KMS ITBs ![]() Now onto setting end gaps for the pistons rings.
Update: shortblock is together. Also did a small check with the fan and fanhousing to see how it would look.
Question: I'm looking into the options of mounting a CHT sensor.
What is a good option? I have seen this one: https://www.stuttgart-classica.co.uk/enginedrivetrain/p/gearbox-transmission-bearing-retaining-plate-84j66 Also turbokraft has an option.
One side completed. Went together smoothly. Love the stomski circlip installer.
Jesse '76 911 backdate with Carrera 3.0 engine Last edited by Jesse911; 11-27-2025 at 03:00 AM.. |
Finished the other side today. Nest week cams and cam timing.
Did a quick mock up. ![]()
Set the cam timing both sides equal. Added all the other rockers and adjusted all valves. This was my first time setting the cam timing. Lots of videos on youtube helped me.
Need to drill the cam sync and than fit the fanshroud and all other parts. ![]()
Try not, Do or Do not
You can install the pistons and cylinders without having the head studs in your way. It makes installing Ps & Cs so much easier. Can easily save 2 hours of assembly time.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Where did you get that front pulley? Harbor freight? Looks like it came off an air compressor. lol
Just teasing you. It looks like you're doing a great job. ![]()
Hahaha, it is from Adapt Motorsport in Switzerland. Modelled after the Campagnolo wheels. Might be hard to see but in real life it is a nice piece!
It's my sense of humor. You're doing great, keep up the progress and you'll soon be making smoke.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Jesse911- we are fans of the ECUMASTER EMU BLACK as well. Have used them on a couple of 3.2 turbo conversion builds, a 2.7 ITB motor, our Shop Mini and will be putting one in our Radical SR3 Racecar. You will be pleased with it I am sure.
Great looking build, nice job. Cheers
