Dr J's Avatar
Engine camshaft condition opinion
I have a camshaft for an SC with a small pitted area in one lobe. The other camshaft has no pitting. I am looking for suggestions about what to do about it before reinstalling.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 02-27-2025, 04:08 PM
Jeff Alton's Avatar
Repair/regrind. That is not getting better, only worse.
Contact John at DRCamshafts.com he is a frequent contributor hear and has done our camshaft work for countless years.
Cheers
www.turn3autosport.com
Old 02-27-2025, 04:18 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Agree with Jeff. Now is the ideal time to have DR regind both cams. Have a close look at your rockers too, the bushing and faces.
1986 Targa Guards Red
2021 MT09 SP
Old 02-28-2025, 04:15 AM
Dr J's Avatar
Thank you gentlemen. Will do.
Old 02-28-2025, 07:31 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Given the need for regrinding, you might think about upgrading to a 964 profile.
This grind will reduce the base circle but the results are certainly withing reason.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-28-2025, 12:48 PM
I agree, I’m happy with my 964 regrind in my 3.0, you probably should refinish the rocker arms and check the bushings.
Old 03-06-2025, 08:04 PM
Dr J's Avatar
Based on Henry’s suggestion I did some research on PP about the 964 cam and ppl say you lose some mid range torque and gain hp on top. Is that your experience porschedude996?
Old 03-07-2025, 06:20 AM
Subtle cam changes can be deceptive.
Given the timing range of most cams in 911 engines, you can advance your cam timing to facilitate lower RPM range.
How much you can advance the cams depends on your piston dome configuration.
Early SCs used .9-1.3 as the range and later SCs used 1.4-1.7.
Later SCs used small intake to also increase low end performance.
Keep in mind that advancing the cams can/will affect dynamic compression.
Henry Schmidt
Ph: 760-728-3062
Old 03-07-2025, 07:52 AM
