Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
As for GT3 cranks, just a half formed daydream that a little more stroke would nice. The reality is that I rarely drive my 3.4 nowadays and if anything, I really should redo the muffler with something more free flowing. I generally fritter away my time with old motorcycles nowadays. Just finished the resto of my V7 Sport and have started tidying up a Katana:
Now that is a build. If I was back in Germany this is what I would do also... Hope you post the outcome, here or another thread. Erik
1986 911 Coupe 1986 911 Targa |
Thanks to everyone posting so far. I am heading out from the Midwest to the Texas Hill Country Rallye tomorrow (March 12, 2025) and won't be back for a week. Hoping to see some unique set ups at the event and get a better feel for things, 3.4 wise.
Been some really great input and I will keep posting as my build progresses. I have two 3.2 engines and this build I may go with the basics but with the info provided I have a lot to research for the next build. Thanks again to everyone at this point. If not for my knowledge hopefully a thread like this will help others down the road... Erik
1986 911 Coupe 1986 911 Targa Last edited by fallingat120mph; 03-11-2025 at 05:57 AM.. |
Points all taken for sure. I just didn't want to be a presumed owner who just throws money at everything for a fix/build that I had no part in. I work on all my cars but this is new territory for me so getting some shop help, especially as I am in the process of moving across country. The regrets are what I am most interested in. As we all have come to hate the phrase "while you are in there", I feel I was very much at that crossroad in real time. I will be happy with any conversion as I am learning a lot, but I hear a lot of the "what ifs" and "should have done this" when it comes to rebuilds and mods. Appreciate the responses! Erik
Thanks for chiming in. Read this thread, albeit older, about the DC35's: https://forums.pelicanparts.com/911-engine-rebuilding-forum/1039196-964-vs-dc35-cam.html
Just some engine porn to keep the faith in those waiting to get to this point.
Builder is letting me do a few things - today's task is replacing valve seals. He also has picked up various deficiencies in some parts such as the Victor Reinz aluminum washers for the case are too soft - getting them replaced with steel and deformed nuts to replace the nylocks. The ARP through bolt kit is very good....very nice and will last forever. Had to clearance the Turbo pump to clear the Carillo rods. Oh yeah, bearings are all good - measured out fine and have the Calico's ![]() ![]() ![]() D. |
The more threads I read on the 3.2 to 3.4, the more apparent it becomes that there really are two different worlds that most of the street cars are living in:
93 octane & No Cat/no smog -or- 91 octane + Cat/smog (I’m in this group) I’m building a 3.2 to 3.4 with 964 cams, single ignition and stock exhaust & DME, with some mild head work to bring the CR down. Not expecting a lot regarding performance gains. Is there anyone here who has consistently passed Cal smog with a 3.2 / 3.4 and a modified chip?
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region |
Good stuff! Well, the 3.4 slightly used set didn't work out after careful checking...few items were not too far out of spec but neither I or the mechanic were comfortable with things...had hopes, but... So ordered a new set of Mahle P&C and will be going forward with twin plugging plus a lot of other things... Just ordered, and am lining up cam work. Since I am completely doing a 180, so to speak, will post as progress moves forward. Was okay with "keeping things simple" but guess that ship has sailed! Erik
Quick question as I am trying to research and getting a better grasp on the big picture of my new direction/build. Through the years I see the "oil pump" and "oil cooler" upgrade and am wondering for your build if it's a necessity or just an upgrade? I ask this respectively and am just trying to study/read at what point in a 3.2 to 3.4 build an improved oil cooler or oil pump is needed, if at all? Just reading through B. Anderson's book (Porsche 911 Performance Handbook) over the weekend...which might be more dangerous than helpful ![]() Thanks everyone... Erik
1986 911 Coupe 1986 911 Targa Last edited by fallingat120mph; 04-16-2025 at 10:25 AM.. |
What brand nose bearing is that? I didn't know they made them without the notch at the top?
I just checked over the parts list and it was a Porsche bearing....now, I bought it around 2007, so things may have changed. D. PS: Engine is now safely back in my garage, just trial fitting all the ancillaries and figuring out how all of this goes together. Been running into dumb stuff like forgetting to rebuild the throttle plate, so off to the bead blaster and plater go those parts
Ok, slowly making progress, large PITA with the modification of the engine tin to deal with the engine moving 25 mm to the rear...that stuff is absolutely the worst sheet metal on this planet.
The wiring harness is all fabbed up along with the mounting plate for the Motec dual lambda CANBUS splitter, the MAP and the exhaust cut-out valve. Had to fiddle with the mounting of the manifold for the vacuum ports and the heater tube was a ***** with the Eisenmann/CarGraphic + cats + exhaust valve combo. Now I am fighting putting the air horns into the air cleaner, how the hell are you supposed to tighten up those 8 mm nuts that retain the horns and the lower air cleaner housings? There is absolutely no room for a nut driver, wrench, socket or whatever...any ideas? What's the trick? Anyway, here are the latest pics...going out to put in the vacuum takeoff for the cutouts including check valve plus some minor parts to be bolted on. ![]() ![]() ![]() D. |
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry, your suggestion was spot on. Bought the swiveled socket just like your picture - I did not know such things existed and the nuts went on quite easily.
Air cleaner now fitted, probably will cut down the snorkel a bit, although Grok tells me there is no material difference in air flow between the 57 mm diameter as it is versus the 77mm diameter I want to cut it down to. ![]() D. |
Grok is an idiot.
That snorkel will work as an air restricter much like the restricters used on racing engines ti limit horse power output. Keep in mind that the air filter housing your using was designed as a silenser on engines making less than 180hp. Here are two ways we've handled the issue of restrictive air flow. ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 07-18-2025 at 11:04 PM.. |
Thanks again Henry. It seemed a little counterintuitive as that hole in the snorkel looks awfully tiny compared to the 6 x 46mm throats on the PMO's.
I will probably cut the snorkel down to just before the 90 degree bend starts - it rains lots here and I sorta think a little bit of snorkel will help keep some of the water out. Its plastic anyway, easy to cut and form.... D. |
Venturi 46mm=1662mm2 x 6 = 9,972mm2 The snorkel looks to be about 60mm = 2827.4 mm2 Of course the CFM of the engine is not in direct correlation with venturi size. Something else we've done is to cut out the opposite end of the filter housing, moved the breather hose attachment and welded in a screen. the noise level in the car goes up but the engine can breath. I would save the intact snorkel and look for a snorkel from a 72-73 US MFI. They are already short. Intact intake parts are getting harder to find. Maybe someone is looking for your snorkel for their concours project.
I tested the effect of the inlet on the dyno. It is a restriction. You can see the results in this post
https://forums.pelicanparts.com/porsche-911-technical-forum/1151593-dyno-summary-testing-early-2-4l-2-5l.html John |
