Try not, Do or Do not
Henry Schmidt's Avatar
Supertec 3.1 liter Short Stroke 9000 RPM 2 valve
1982 930 Turbo case (GT3 squirters)
Shuffle pins
Boat Tail
Supertec SuperCrank billet 66mm full cross drilled
R&R billet connecting rods (GT3 config: 53mm big end, 21mm small end & 130mm oal)
GT3 Bearings coating by Calico Coating
996 TT oil pump
Racing IWIS chains
Supertec idler arms
964 steel countershaft
Supertec Head studs
LN Nickie cylinders 100mm
Supertec 906 cooling tin
10:1 JE FSR pistons, 60 grams lighter than conventional pistons
Custom DC 80 cams
Early forged rockers w/dry film pads
Extreme Cylinder heads
Port Flow Analyzer v3.0 EXTREME CYLINDER HEADS
Test Comments:
Vlv Dia
1.850"
1.575"
Stem Dia.31"
Lift Range Test Flow Leak Corr Pres Pres CFM
Int #1 .100 4 28.00 34.00 .0 67.7
Int #1 .200 4 28.00 79.00 .0 157.2
Int #1 .300 5 28.00 73.50 .0 216.8
Int #1 .400 5 28.00 84.00 .0 247.8
Int #1 .500 5 28.00 89.50 .0 264.0
Exh #1 .100 4 28.00 25.00 .0 51.3
Exh #1 .200 4 28.00 53.00 .0 108.7
Exh #1 .300 4 28.00 75.00 .0 153.8
Exh #1 .400 4 28.00 87.50 .0 179.4
Exh #1 .500 4 28.00 93.00 .0 190.7
50mm PMO Carbs (manifolds 41 x 50mm)
Burnham Motorsport Twin plug distributor
Burnham Motorsport sump cover
Series 900 fan shroud
Supertec Power Pulley
Supertec RSR flywheel
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-08-2013, 02:15 PM
Henry Schmidt
Ph: 760-728-3062
Old 05-08-2013, 02:21 PM
I forgot to mention:
Extreme Cylinder valve springs and titanium retainers
Hargett valve covers
M&K RSR muffler
Ceramic coated 1 3/4 German Racing headers
Custom wiring harness by Supertec Performance
Henry Schmidt
Ph: 760-728-3062
Old 05-08-2013, 02:31 PM
Straight shooter
Lapkritis's Avatar
Porn-sche. Looks fantastic.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 05-08-2013, 02:46 PM
BURN-BROS's Avatar
Now that's a proper short stroke
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 05-08-2013, 02:56 PM
GrantG's Avatar
Cool - what sort of HP at which RPM do you expect (and RPM at peak TQ)?
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 05-08-2013, 02:57 PM
KTL KTL is online now
Schleprock
KTL's Avatar
SHAZAM............. That's hot.
If someone asks whether you used the cam oil line restrictors, you have my permission to internet-punch them.
What type of intake valve covers are those?
Kevin L
'86 Carrera "Larry"
Old 05-08-2013, 03:30 PM
GrantG's Avatar
These:
HPP Porsche Valve Covers - Porsche Products HPP
Old 05-08-2013, 03:38 PM
Would look nice in a well set up 944...
I must take a cold shower now... Beautiful!!
Old 05-08-2013, 04:28 PM
pete3799's Avatar
Yes please.
Pete
79 911SC RoW
Old 05-08-2013, 04:55 PM
Only a guess but we're hoping for 340 hp @ 8200 (maybe more as it approaches 8500 if the headers are right) with 250 ft/lb @ 6500 ??
I wanted to use a better set of headers but at some point you have to just run it and see what you get.
Henry Schmidt
Ph: 760-728-3062
Old 05-08-2013, 04:56 PM
WOW... Now I'll need to buy another car so I have an excuse to have you build one for me
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 05-08-2013, 05:23 PM
This is nothing but pornography and should be banned - banned I say.
914/6 GT (Repro) Tarmac Rally car
928 S4 - 1989
911SC - 1980
944 TURBO - 1986
944 S2 - 1990
Old 05-08-2013, 07:21 PM
bavaria911's Avatar
Henry,
Amazing! You just keeping pushing the envelope on engine design.
Vr,
Scott
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 05-08-2013, 07:57 PM
Evan Fullerton's Avatar
I see headers being a limitation. We saw 18whp more with a custom set of stepped headers then 15/8" euro George's on a mostly stock 3.2L and we were able to pull timing out and maintain power. I would think there are probably larger gains to be had with big cams.
None the less. SWEET engine. Any reason other then cost why you aren't using Ti GT3 rods? I was given a set and have been salivating over getting them into my 3.0L.
Old 05-08-2013, 09:40 PM
fred cook's Avatar
Beautiful job.......
As always, a beautiful job! I know the owner of this engine will be a proud papa!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-09-2013, 05:25 AM
fred cook's Avatar
Cylinder air shrouds
Just noticed that the ones on your engine look different than the ones off my 3.0 SC engine. Are they more efficient? Something you make in your shop? Are they available to us mere mortals?
Thks,
FEC3
Old 05-09-2013, 05:28 AM
Less brakes, more gas!
euro911sc's Avatar
He makes them. I have them on my 3.0l. I believe they are 904 inspired or something like that.
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 05-09-2013, 06:41 AM
When we considered the RPM we were trying to achieve and mixed it with a piston 30% heavier than a GT3 piston, we thought (perhaps conservatively) that the titanium rods would add another layer of maintenance.
Plus, I really like the R&R rods that Charles @ LN Engineering sells.
Henry Schmidt
Ph: 760-728-3062
Old 05-09-2013, 07:02 AM
Thks,
The tin is made by us and is a replica of the 906 cooling tin. When we made our 81mm Nikasil racing cylinders, we replicated the cooling fins of the 906 cylinder and this cooling tin promotes higher air flow. That in combination with the Power Pulley that reduced fan speeds, the cylinders can pull more heat from the heads.
Henry Schmidt
Ph: 760-728-3062
Old 05-09-2013, 07:30 AM
