Originally Posted by OsoMoore View Post
I was in first gear during the initial bang-bang-bang. I did try re-engaging when I thought it was still running, to see if I could get speed to clear the tunnel and construction zone. I think that was when I confirmed the engine had stopped.
It was an awful spot to have something go wrong - construction in a tunnel. I have a lot of what-ifs looking back at it. What if I'd cut power as soon as it sounded off? I did end up having to push the car out the last bit, but I made it most of the way out before then. I'm glad I didn't end up run over in the dark.
That was a bad spot to break down.
So you heard/ felt the bang, you must have pushed the clutch in, then thought it was still running and let the clutch out. Did you let the clutch all the way out? Or maybe just until you felt resistance? I guess that could have spun the engine which stripped the cam gear and as Danobee wrote, loosened the nut.
The rocker shaft misalignment theory is looking like a top contender.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 07-07-2025, 03:39 PM
917_Langheck's Avatar
Originally Posted by David Inc. View Post
There's a reducing gear between the crank and cams that changes rotation.
Edit: Ask a 996 owner, it's their favorite part!
For whatever reason I misremembered that change of direction. More sleep, must get more sleep...
Old 07-07-2025, 04:42 PM
OsoMoore's Avatar
Its hard to piece together exactly what was happening with trying to find a spot, analyze the noise in a noisy tunnel, and watch traffic. I think I tried to let up on the clutch to see if I could get more power to make it out of the tunnel, and found that it was slowing me down instead, so that would have attempted to spin up the engine.
Time to pull it a part a bit more before bed, will post back soon.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 07-07-2025, 05:39 PM
OsoMoore's Avatar
Analysis later, here are the photos from finishing bank 1. Video later.
Old 07-07-2025, 07:18 PM
OsoMoore's Avatar
Old 07-07-2025, 08:14 PM
OsoMoore's Avatar
Sooty but no major visible damage on bank 2.
Picture order is 4-5-6 left to right. Note the bit of metal caught in 6, holding the exhaust valve open a fraction.
Cylinders in order 4-5-6 right to left. They are also quite sooty, a little bit of metal scraps in there. Potentially fell in during the many engine flips on the stand. Didn't spot any scarring on the cylinder walls with a cursory look.
Next disassembly steps are to get the chain ramp off so I can remove the chain housing on bank 2. They wiggle but do not come free.
I'll consult the book for the next step after that!
Old 07-08-2025, 04:59 AM
I know it's my theory but now I don't love it--I think I'd expect to see more wear on the cam lobe if the rocker had been sticking.
1982 911SC
Old 07-08-2025, 05:25 AM
OsoMoore's Avatar
I'll take a look at the cam lobe for #3 intake during lunch break. Also I'll check the position of the rocker shaft and see if it was far enough over to potentially expose the seal and jam the rocker action.
Old 07-08-2025, 06:15 AM
OsoMoore's Avatar
Number 3 cam lobes intake and exhaust are both scarred. All the junk flying around, plus the jam, contributed to that. I think the jam was on the exhaust (leftmost in the photos).
Interestingly, it appears the barrel/shaft (not sure of the name) on which the rocker arm rides must have been very far out of center. Here is the barrel re-inserted without the rocker arm, so you can see the position of the seal.
And here is an earlier photo from disassembly showing how far it was before I touched it. It is significantly farther than even my re-setup photo.
So the barrel was far-far-far out of center, possibly far enough that the barrel was actually only seated on one end. Could this possibly lead to the rocker misbehavior, valve collision, and cascading failure?
Old 07-08-2025, 10:29 AM
Wow, do the cambox bore or inner faces have markings? I would expect the rocker arm to bind if the shaft went out of alignment when the end fell out of the cambox bore. Was that shaft difficult/easy to remove?
-Kelly
Old 07-08-2025, 12:06 PM
OsoMoore's Avatar
-Kelly
All the shafts took a little bit of convincing to come out, but not a remarkable amount. I can take high detail photos later of each of the components of the #3 intake valve, and check for markings on the rocker and shaft and where it mounts in the case. I re-assembled #3 rocker and shaft and it moved smoothly at that point.
Is that what you mean I should check?
Old 07-08-2025, 12:52 PM
When you blow up, inside the intake broken parts float from side to side. Things don’t stay in the area of the mess.
Bruce
Old 07-08-2025, 05:04 PM
OsoMoore's Avatar
Work proceeds - bank 1 cylinders and pistons out. Tomorrow morning we flip and finish the pistons and cylinders.
The rod for #3 has a serious scar on it, probably will need to be replaced.
Old 07-08-2025, 06:47 PM
That’s the first time seeing that picture, Yes, ground zero, that shaft walked out and seized.
Old 07-08-2025, 07:16 PM
OsoMoore's Avatar
Now I'm kicking myself. If I'd done a valve adjustment recently, I'd have had that lower valve cover off and noticed the out of place shaft.
I wonder if I should buy those locking shaft nuts.
Old 07-08-2025, 08:07 PM
Still here
pmax's Avatar
The valve didn't get chewed up, looks more like it punched a hole in the piston !
Old 07-08-2025, 08:25 PM
OsoMoore's Avatar
Originally Posted by pmax View Post
The valve didn't get chewed up, looks more like it punched a hole in the cylinder !
Wow, that's wild. The design of these things is that the rocker breaks when things get bad, saving the cylinder, heads, etc. But in this case
Old 07-09-2025, 03:07 AM
Crrrap! you saw the shaft out of position, that stings. I'd read a few of your earlier posts, was that tinking noise from the same side? Might that have been the earliest warning?
Sorry about this, but it's kind of fun (the rebuild process) and you're moving right along...
Phil
81 SC.
930/16 (us model)
Old 07-09-2025, 07:17 AM
OsoMoore's Avatar
Phil
Do you mean the brief noise right before the engine failure? With that, I didn't notice any specific direction other than "behind me" from the driver's seat.
Old 07-09-2025, 07:29 AM
Sorry, it was another poster's thread from the past about engine ticking sounds you'd responded to.
81 SC.
930/16 (us model)
Old 07-09-2025, 07:40 AM
