OsoMoore's Avatar
Parts have arrived at the shop, will be picking them up tomorrow. I've reviewed and re-reviewed the assembly chapters in Wayne's book. Kind of daunting, but I'm ready.
Hoping to kick off work this weekend. First step is cleaning, second is crankshaft assembly. One step at a time!
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 09-04-2025, 07:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
I'm pretty busy but if you find yourself in a quandary, give me a call.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-04-2025, 07:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
OsoMoore's Avatar
Thanks Henry!
I took a half day off work and brought all the parts home this morning. This weekend I will organize everything, divide parts and supplies out into the 10 stages from Wayne's book, and make sure I have everything needed to start stage 1.
The plan is to prep 1 or 2 stages ahead, so I can be sure when I have 6 hours free I am ready to do the work. When I have less time free, I can do cleaning and such.
Old 09-05-2025, 11:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
OsoMoore's Avatar
Parts have arrived, and I'm beginning final cleaning and assembly. I have a list of sealants and glue-things to get:
1) Loctite 271 (or maybe Permatex?) for bolts.
2) Loctite 574 for case sealant
3) Curil-T for... seals? Curil-T is hard to get, its been replaced with Curil-T2. Is T2 OK?
4) Black silicon sealant
5) JB Weld
6) Assembly Lube
In a couple steps, I'll need to handle the chain and rods while closing the crankcase. Any suggestions or tricks, or should I just get my hands on the official chain and rod holder tools?
For now, I'm cleaning crevices and corners. I think I need to find a stiff brush with a tip. Maybe something made for cleaning firearms? Getting off the excess sealant from 25 years ago looks fun!
Old 09-07-2025, 04:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
hmmm... what's the black silicon sealant for?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 09-08-2025, 02:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Oso, before you proceed, I suggest you have a close read on this thread:
https://forums.pelicanparts.com/911-engine-rebuilding-forum/284737-complete-engine-sealant-thread.html And black silicone is not part of the sealant list, best leave it on the shelf.
1986 Targa Guards Red
2021 MT09 SP
Old 09-08-2025, 04:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
OsoMoore's Avatar
This is what Wayne's book recommends with the silicon sealant.
Old 09-08-2025, 05:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
OsoMoore's Avatar
Ok, digging in... I also have some recommendations from the local Porsche shop.
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
It's a 914 ...
stownsen914's Avatar
You'll see different recommendations on sealants. Have a look at the sealant thread - collective knowledge from multiple pros who have assembled thousands of 911 engines between them. I figure they know what works.
Old 09-08-2025, 05:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
OsoMoore's Avatar
Yikes, 38 pages! Working through it slowly. Currently (page 11) looks like Henry's sealant kit (available on our host) has everything I need, and page 1 and this picture say where to put it.
https://forums.pelicanparts.com/3424799-post34.html
I'm sure I'll learn more over the next 27 pages and remaining 15 years of posts.
Old 09-08-2025, 09:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
OsoMoore's Avatar
More progress on the sealant thread, not done yet. What a massive thread and some of the discussion gets... spicey.
But I'm seeing a recommendation that I chamfer my through-bolt holes. I suspect that was already done by previous rebuild, will check tonight.
Old 09-08-2025, 02:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
One of Wayne's advisors was clueless. I did a whole thread on one of his nightmares years ago. I don't use his name anymore because I think he dies. The engine was so hideous that the owner brought it to us to reassemble before he ever started the engine. Glue was applied like there was a prize for the ugliest over-glued engine. Black silicon applied to every possible leak point. Oil return tubes, rocker shafts, flywheel and front pulley seal and even valve cover gaskets, but the list goes on.
Never use blue case through bolt o-rings. Have the case holes surfaced (mag cases only) and put them together with green Viton o-rings and a high quality o-ring lubricant.
The glue on that case looks like epoxy applied to the outside as an attempt to slow case leaks.
Henry Schmidt
Ph: 760-728-3062
Old 09-08-2025, 07:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
OsoMoore's Avatar
That's terrifying!
My case is aluminum, and I'm planning to pick up your sealant kit (waiting to finish the sealant thread in case there is more guidance on that) and the green o-rings that come with it.
Do I need to chamfer the holes on an aluminum SC 3.0 case?
Old 09-09-2025, 03:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
And one other piece of advice to ignore is the recommended of the use of Locktite on the rod bolts.
2021 MT09 SP
Old 09-09-2025, 03:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
OsoMoore's Avatar
I didn't see anything about that (yet). What's the argument for doing that? On its face, it sounds like loctite there is really important.
Old 09-09-2025, 04:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
It's a 914 ...
Rod bolts/nuts don't fail due to just "coming loose"
Old 09-09-2025, 05:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
Thread lockers can effect torque values. Threads lockers are generally counter indicated on stretch bolts.
To my knowledge, every manufacturer of high quality rods and rod bolts, supply a thread lubricant to promote consistent torque values. Notably, ARP has it's own branded lube with their bolts.
Henry Schmidt
Ph: 760-728-3062
Old 09-09-2025, 05:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
OsoMoore's Avatar
Thanks Henry, I received my reconditioned rods back from the shop assembled with the new bolts on them, shop recommended moly lube and no loctite.
Just ordered your kit from our host, should arrive in a few days. I'll probably shoot to assemble the case in 1.5 weeks over the weekend, when the kit has arrived and I can borrow the chain and rod holding tools. I'll plan to put together a step-by-step procedure and post it here first.
Old 09-09-2025, 07:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
Here is an engine built by the "black silicon" guy.
Note the LocTite on the flywheel bolts, also contra-indiated.
Henry Schmidt
Ph: 760-728-3062
Old 09-09-2025, 09:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
I always wondered about the use of Loctite on engine parts as the temperatures would be likely so hot as to render the locking effect null. Am I correct?
Rutager West
Old 09-09-2025, 10:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
