-   -   1979 SC Chewed a Valve - Total Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1179839-1979-sc-chewed-valve-total-rebuild.html)
OsoMoore 10-24-2025 06:04 AM
Is this basically what we're doing? I feel like I must be missing something, because if this would mean we don't care what the depth gauge values are, just that we find the peak.
I'd like to know what is actually happening, not just the list of directions to do the timing.
http://forums.pelicanparts.com/uploa...1761311093.png
stownsen914 10-24-2025 06:31 AM
That's basically what's happening. One minor clarification is that when you set cam timing at TDC overlap, the cam is at the "measured lift" spec for your cam (e.g. 1.1-1.4 mm for an SC or 3.2 Carrera), not full lift. I realize you probably already knew this.
If you want to visualize what's happening as you do your cam timing, it can help to have a degree wheel. Even just a printed one taped to your pulley can help visualize.
OsoMoore 10-24-2025 06:45 AM
So if you're doing "measured lift" and not full lift, couldn't you be at either the rising edge or the falling edge, and not know which? I guess if you are rotating clockwise you can verify if you are rising or falling by first finding the peak, and then either watching for your desired lift before or after the peak.
stownsen914 10-24-2025 06:55 AM
If you are not careful, then yes that could happen. The usual timing procedure has you start with crankshaft at TDC, and camshafts on both sides with the dot or "930" mark pointed vertically (or with the keyway pointed up, in case the other marks are not there). This has you starting in the ballpark, and then you turn one revolution of the crank to get to TDC overlap on #1 do the small correction to get to the measured lift spec. If you follow that procedure, you won't be far enough off to have the issue you mentioned above.
OsoMoore 10-24-2025 07:02 AM
Ah, so you end up doing this?
EDIT: Typos in my image below.
2.d Unlock crankshaft from camshaft, leaving camshaft at measured lift.
2.e Rotate crankshaft back to TDC.
http://forums.pelicanparts.com/uploa...1761314450.png
And I need to check Wayne's book or something to get that desired lift value for my engine.
stownsen914 10-24-2025 08:01 AM
Edit - realized you have the early style camshafts with the big 46 mm nut.
The basic idea is the same to do the cam timing for the early and late cam timing procedures, but the details are slightly different. With the early style camshaft, you have the option of turning the cam with a wrench. With the later bolt style, this is trickier.
The early procedure basically has you turn to TDC like in your 2) c. and then do the correction by unlocking and turning the camshaft.
In the later procedure, since you can't turn the camshaft easily, the procedure do 2) c. by turning to the valve measured lift spec and then unlocking and turning the crank to TDC.
Your summary seems like it might be mixing the two a little but it looks more like the late procedure. Wayne's book covers both. Have a look and you'll get the idea.
Flat6pac 10-24-2025 05:28 PM
Check the Stomski Racing video on setting cam timing. So much easier than guessing.
Bruce
OsoMoore 10-24-2025 06:28 PM
Bruce
Wow, their tools are so slick! I've got some nice stuff borrowed from the local shop for the weekend, but not this newest stuff.
PeteKz 10-24-2025 11:28 PM
Originally Posted by OsoMoore (Post 12552235)
Got five replacement rockers from another Pelican. I'll plan to send the set out for refurb later. But these should be fine for finishing the rebuild. Ice comes in November and I can pull them out then.
As I recall, I can get them out without too much trouble just by removing the valve covers.
It sounds like you intend to put the engine back in and drive your car for a few more weeks.
Yes, you can remove and replace the rockers with the engine in the car. I have done that and it was a major PITA (to install RSR o-rings on the shafts). I strongly advise that you install rebuilt rocker arms now and save yourself that trouble and cussing. Just buy a set from Henry or another vendor on an exchange basis.
OsoMoore 10-25-2025 01:07 PM
Some good points on doing rockers now, seriously considering sending them out this week while I finish other stuff. I can always put them back in last before I push the engine back in.
Finished cam timing today with the borrowed tools. I'm still using the old slightly damaged locking pin, so I didn't torque one side down. The new pin comes Tuesday. But that doesn't stop me from finishing the timing itself.
All the stud stuff is sorted out, just need to oil-bathe my new tensioners and put them in place of the rigged stuff for setting timing, sometime tomorrow.
Aren't these things just so beautiful?
http://forums.pelicanparts.com/uploa...1761422836.jpg
OsoMoore 10-27-2025 05:38 AM
Timing is set! Rockers will be heading off to Supertech this week. A few parts are getting in Tuesday and I should be close to buttoning it all up.
http://forums.pelicanparts.com/uploa...1761568717.jpg
OsoMoore 10-27-2025 07:32 AM
The next step in Wayne's book is to check the piston/valve clearances. Based on my recollections of initial reading last night:
1) Install the Cylinder 1 and 4 Exhaust and Intake valves.
2) Verify at least 1.5mm clearance on intake and 2.0mm clearance on exhaust.
The exact way to do that is still a little fuzzy to me. I should be able to track the highest points on the piston travel based on crankshaft position. I'm not sure how best to measure the gap to the valves.
I have rebuilt heads, but they are my originals. I have new P+C from Mahle (9.8:1). I have my original crankshaft and crankcase, and rebuild of my original cams in my original cam towers.
What is the best way to measure this clearance? Any tricks to it?
OsoMoore 10-27-2025 12:27 PM
One potential approach I found:
1. Set your normal lash to 1mm.
2. Rotate to expected point of closest contact for the cylinder.
3. Zero out your depth gauge on the valve edge.
4. Adjust the valve screw down until you feel it stop against the cylinder head.
5. Read the difference from where you zeroed the gauge.
I'm hesitant to try this, as I suspect I'd need a lot of force to turn the screw against the valve springs, which could lead to damaging something when I reach the piston.
Is this a real way to do it?
Henry Schmidt 10-27-2025 01:06 PM
http://forums.pelicanparts.com/uploa...1761593856.jpg
It's hard to tell if you're using wide tensioner/idler arms.
During the early air-cooled 911 days it was thought that tensioners were failing do to heat and poor design.
By the time the factory started using pressure fed tensioners, they had determined that idler arms were binding on the shaft, creating a harmonic that caused the tensioner to fail. They may have introduced the wide arms when they redesigned the 930 tensioner but wide idler arm certainly were installed in all pressure fed tensioner after 1984. The tensioner kits never included new/redesigned arm so most retrofitted tensioner kits were installed using a spacer.
A few years back the left side arm became unavailable so we made a bushing to simulate the wider arm configuration. I liked the modification so well that the one-off prototype became a regular in all of our engines.
We modify stock idler arms and sell them on an exchange basis.
We also upgrade factory wide arms with a propitiatory DP4 bushing for those concerned about wear in their existing arms.
http://forums.pelicanparts.com/uploa...1761595531.JPGhttp://forums.pelicanparts.com/uploa...1761593872.JPGhttp://forums.pelicanparts.com/uploa...1761593872.JPG
OsoMoore 10-27-2025 01:22 PM
My tensioners were upgraded to oil-fed in 2001, and they have the spacers on them. I didn't buy the car until 2013.
Lee's post about installing them.
I feel uniquely blessed to have this much of my car's history recorded on this forum. And it is amazing to read Lee's accounts of him doing the same stuff I'm redoing 25 years later.
OsoMoore 10-27-2025 01:26 PM
Oh my god, seeing John Walker's posts on that old thread. And he's around helping us out again. Good times.
Henry Schmidt 10-27-2025 02:12 PM
Just to be clear: The pressure fed tensioners without wide idler arms is not the proper way to build these engines. These engines are expensive to build so ignoring modern build techniques is foolish.
stownsen914 10-27-2025 02:35 PM
To check your piston to valve clearance - since the engine is assembled already, your best (only?) option is to do the valve adjuster screw method. There's nothing wrong with that method as a sense check to make sure you have proper clearances. I don't recall if you are reassembling with stock parts. If that's the case, you really shouldn't have any issue anyway, but good to check. If cams, pistons, etc. are non-stock, you should definitely check clearances.
Turning the valve adjust screw by hand while the engine is not turning, to make sure you have 1.5 mm, won't damage anything. The resistance turning the screw by hand will be constant unless a valve touches the piston, which you will easily feel. The screws are conveniently 1.0 mm pitch, so just turn 1.5 turns. If you don't feel anything, you're good.
I'd think using the Z1 pulley mark or whatever you used for cam timing is fine for knowing where TDC is. If you used non-stock parts, or expect close clearances, some advocate for checking 5, 10, 15, and 20 degrees before and after TDC. With some cam grinds, the valve will open faster than the piston moves away from it near TDC.
Some also suggest to just turn the screws in 1.5 turns and turn the engine over by hand. Personally I didn't use that method for my engine. I think you wouldn't have nearly as good a feel for any contact that might happen, and I'd worry about bending a valve.
OsoMoore 10-27-2025 06:09 PM
Diverging from the valves/timing question. I found this bag of what I believe are valve stem seals in my box of new parts. But I sent my heads to a shop and they came back all redone with springs and all. I'm not sure these are any use to me at this stage.
http://forums.pelicanparts.com/uploa...1761613761.jpg
OsoMoore 10-28-2025 06:49 PM
While I wait for shipping to and from Supertech, I'm working to get the rest of the steps ready to rock. Exciting things like meticulously cleaning all my rocker arm barrels.
I realized I'm going to need a ton of oil for the break-in oil changes. Like 45 or 60 quarts-worth.
Any recommendations on how to best get that much 20W-50 dino oil?
stownsen914 10-28-2025 06:56 PM
How many break in oil changes are you planning on doing?
OsoMoore 10-28-2025 07:14 PM
The red book says:
1) Fill with 10'ish quarts
2) Run 20 minutes first break-in, change the oil again.
3) Three short drives, change the oil again.
4) After 500 miles, change the oil again.
5) After 1000 miles, change the oil again.
I have a front oil cooler too so... lots of oil.
mikedsilva 10-28-2025 07:41 PM
60 quarts?
I must be doing it wrong.
OsoMoore 10-28-2025 08:43 PM
Yeah, it seems like a lot to me too. I am more than happy to hear other directives, that's just the source I've been mostly working from to date.
PeteKz 10-29-2025 12:34 AM
That's overkill. If you use a "break-in oil," then follow the manufacturer's recommendation on when to change it to regular oil. After that, change the filter once or twice before you get to the regular change interval. Done.
Yeah, I know, there are videos by Lake Speed Jr. and others that say you should use a break-in oil (but remember, they are in the business of selling oil and oil-related services and products). I've spent way too much time chasing down rabbit holes about oil and reading SAE papers and the like, and the conclusion I've come to is that there is a lot of misinformation about oil. Follow the manufacturer's recommendations for break-in (Porsche) and you'll be in the right ballpark.
Note: Porsche does not recommend a special break-in oil.
OsoMoore 10-29-2025 05:18 AM
I'll look around and see if I have that spec somewhere. Or if you have a link, that would be appreciated.
stownsen914 10-29-2025 05:54 AM
My 911 is a racecar, so granted, my oil change intervals are different. But for my engine, Im going to run break in oil for one track day (~60 minutes running time), then change to my regular oil and proceed with regular oil change intervals.
OsoMoore 10-29-2025 09:58 AM
Collecting some break-in related videos to watch later:
Klassic Training School
https://www.youtube.com/watch?v=Ym3O_AhCa-E
https://www.youtube.com/watch?v=JFqRYOylpQk
"Joe Engineer"
https://www.youtube.com/watch?v=_UXaRDUjFNQ
Our very own Mike D'Silva
https://www.youtube.com/watch?v=7mVAl5OYeH0
Planning a little watch party later tonight.
PeteKz 10-29-2025 02:06 PM
I don't have the owner's manual for your car, and the online references want me to buy one. Look there first. But if it's like most of the ones I've seen, it isn't explicit about oil or changes. It basically tells you how to drive the car for the first 3000Km.
OsoMoore 10-29-2025 03:30 PM
I did find the owner's manual page on breakin for the SC. But I wonder if the engines had some initial break-in at the factory before arriving at the customer.
EDIT: It was a Carrera, but probably similar.
https://forums.pelicanparts.com/porsche-911-technical-forum/852691-whats-best-way-break-new-motor.html?utm_source=chatgpt.com#post8498237
PeteKz 10-29-2025 03:57 PM
Only if they ran them on a test stand before installing in the car. It's common for manufacturers to do that nowadays, especially on high performance engines, but whether Porsche did it in the 1980's I don't know. At any rate, the oil that was in the car when it rolled out of the factory was the recommended oil for that car, and most of them had fewer than 10 miles on them when the customer bought the car.
You're overthinking this. I know you're concerned about doing the "best thing" you can for your new engine, but you're obsessing about it. Just put in the oil you are gonna use and go drive the damn thing! A thousand miles from now, it will be running great and you won't care.
brighton911 10-30-2025 04:36 AM
Oso, listen to all the voices of reason, that hyper oil change regime is just bunk. Porsche never has suggested such a thing on their new cars, and the care you have given your engine assembly is likely as good or better than the factory. An oil and filter change after the 500 mile spirited break-in and then the regular interval is all you need. And cutting open the oil filter for examination of the media is a good idea too.
911 Rod 10-30-2025 06:22 AM
I used break in Brad Penn and drove it for 1 hour on a hilly road going from 20 to 50 miles per hour putting lots of load on it. Then changed it to my regular oil.
Henry Schmidt 10-30-2025 06:40 AM
I still use 30 non-detergent when possible. The detergent reduces friction and the point of break in oil is to allow the components to create a working relationship.
30 minutes of stationary time time varying the rpm constantly, adjusting the tune and checking for leaks. Change that oil to your oil of choice, I'm a fan of VR1 20w50 and then a 1 hrs road trip to maybe a favorite restaurant. Let it cool while you eat, maybe a hour and a half or two, then the trip home. Check for leaks, check the timing, do a valve adjustment and drive it to the next oil change.
Removing the plugs to do the valve adjustment allows you to get a feeling for how your combustion is performing.
OsoMoore 10-30-2025 06:50 PM
Thanks for all the advice folks! Sounds like the synopsis is:
1) Start with normal oil. Run stationary 20-30 minutes 2K+ RPM to help new rockers/cams wear in properly. Check stuff.
2) Change oil, adjust cams, new filter, go for a moderate length drive. Check stuff.
3) Change at next interval (Spring in my case).
Tangentially Oil-related question - When Cylinder 3 boomed, one of the effects was a lot of oil in bank 2's exhaust header. They're decently drained, but still a bit oily. Any recommendations besides letting it smoke out at first startup?
http://forums.pelicanparts.com/uploa...1761875298.jpg
PeteKz 10-31-2025 12:28 AM
I'd make a half-hearted attempt to clean out the wet oil with a solvent--say paint thinner or kerosene, or even gasoline. Then I would put the things on and go drive the piss out it (after breaking it in, of course). If it smokes for a few miles, so be it.
Remind me, are you installing the cats? If so, I'd try a little harder to clean out the oil. But not much harder.
OsoMoore 10-31-2025 03:55 AM
I have a CAT... although come to think of it, it may be a bypass. I'll take another look.
UPDATE: its is a straight bypass. Nothing inside it.
http://forums.pelicanparts.com/uploa...1761908118.jpg
Henry Schmidt 10-31-2025 05:39 AM
Most automotive machine shops have a hot tank (high temp, power washing cabinet) for cleaning larger parts like heads and engine blocks. There is nothing in the exhaust (except the cat) that will be negatively affected by the caustic soda generally used in this type of equipment. One side effect is often the removal of old paint leaving you great looking heater boxes.
OsoMoore 11-02-2025 05:38 AM
The path towards finishing next weekend has some new snags - sump plate fitment and missing exhaust stud.
I talked to PP parts specialist on the phone back when ordering my sump plate cover, and now am finding it does not fit over my newer oil pump.
I also found one of my exhaust studs is missing, presumably from the replacement head I bought used and sent right to the rebuild shop without passing through my hands.
Can I use a normal stud on the exhaust, or does it need something special for the heat? Also, I'm now slightly that even the expensive aluminum sump plate won't fit. Hopefully I can get all these issues sorted by midweek to make the big push Thur-Sun.
http://forums.pelicanparts.com/uploa...1762090694.jpghttp://forums.pelicanparts.com/uploa...1762090694.jpg
OsoMoore 11-02-2025 05:41 AM
The oil pump extends almost the length of the studs below the case - nearly 1/2" in the center. Looking at the other sump plates on PP I'm not sure any of them will clear it.
http://forums.pelicanparts.com/uploa...1762090910.jpg
