What studs in clutch end of case?
I was going to start reassembly of my 2.2E engine today. First job of the day - getting it on the stand. But of course, the studs which would mount it were removed and time-serted.
I have the studs I removed but I have no clue which one goes where, also whether some take bolts rather than studs. ![]() Does anybody have a loose engine case with gearbox not attached they could let me know which stud goes where please? Sent from my SM-S918B using Tapatalk |
Actually, hark back to when I bought the engine - maybe the studs were already not present. If so, I think it bought some but I don't know which goes where.
![]() Sent from my SM-S918B using Tapatalk |
Try not, Do or Do not
If memory serves, starter mount is a 10mm allen bolt 102mm long. Later had a stud 10mm x 105mm'and special allen nut.
The lower studs studs are both 10x 69mm. For the purpose of mounting the case on the stand, any 10x1.5mm bolt 20mm longer than your cradle should do.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') Last edited by Jascha; 10-07-2025 at 10:11 AM.. |
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') |
For the broken stud, get a set of reverse drills and easy outs, center punch to give drill location.
I have complete sets of through bolts for early cases. PM if interested Bruce Last edited by Flat6pac; 10-07-2025 at 12:45 PM.. |
I would slit the case on bench, strip all the part from inside and send the case out for EDM. You could try drilling out the stud but you might damage the threads in the process. Either way, inserting all four stud holes is a good idea. If you're not happy with the HeliCoil, simply pull it out and replace it with a Time-sert.
