Gouged Valve Stem Tip
I'm getting ready to install the heads back on my motor and I noticed this gouge in the #1 exhaust valve stem tip. Not sure when or how this happened.
This is a problem, right? Should I have the tip ground to fix this? Thanks!
Ward Komers 1984 944 Track Car - Sold 1968 912 Rust Bucket - Under Repair 1971 911T - Under Repair 2006 Carrera S - Sold |
Hi
Stone or polish off any high material and it will be fine under a standard Porsche swivel foot. Cheers |
Try not, Do or Do not
That is a strange pattern suggesting a manufacturing defect not impact destruction.
I would pitch the valve in favor of a replacement.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I'm in Henry's camp. Considering the consequences of a dropped valve, best to replace it.
1986 Targa Guards Red 2021 MT09 SP |
It looks more like it got beaten out of the guide.
On the other side of the valve grinding machine is the stone to bring it back to "stock." The length of the valve tip protruding from the head is ground down to match how much is taken off of the valve seat during the valve job to keep the rocker geometry stock. They should all be equal, at least in a perfect world. If you don't have access to valve grinding equipment replacing the valve would be the easiest and cheapest way to correct. |
We very rarely surface the tip end of the valve even though the machine has that capability. If you grind a Porsche valve enough that you need to shorten the stem, the head rim is already too thin.
Thanks for the input everyone. I went ahead and got a new TRW valve from our host. Glad to see "Germany" on the box...
new parts when in doubt.
As long as the credo: "sometimes new parts don't work" is applied. Inspect everything.
