Chain fence eating turbo
Originally Posted by cmcfaul View Post
would love 50 hp from a cam. That's about what I got on the 2.4 E going to a DC 30 cam and higher CR.
Seems there is not a lot Porsche missed with the 3.2. Maybe a side turbo when the engine is freshened up. I did get the ARP rod bolts. No money shifts but do run it deep into redline often as the chip allows with no ill effects so far.
tracking down the last bits (yoke, stand).
Chris
Chris
87 Carrera 3.2
I’ll be selling an air-to-water intercooler setup and Holset HX40 soon for cheap. Made a thread on it in the 930 forum under my name.
Would only need headers (or custom fab stock for a turbine T4 flange) and blow-off valve to make work.
Old 12-03-2025, 01:38 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Porsche guy likely doing the head machine work is saying I should replace all head studs. I thought only Delvar studs should be replaced. I think my car has all steel.
Thoughts on proactively replacing all head studs. Would hate to break any in the process.
Chris
89 Carrera
Old Yesterday, 12:55 PM
PCA Member since 1988
My view as a mechanical engineer: If the studs are original Porsche steel, and they do not have significant corrosion, keep them as-is, and don't remove them. If significant rust, you and your machinist decide whether to replace. If the case needs the cylinder spigots machined, then you have to remove them.
What does he want to replace them with--Porsche steel studs? Either way paint them with a good paint to protect against future corrosion.
Caveats: This is for a street car with a 3.0 or 3.2 case, not a racing engine. There aren't other factors mitigating to replace them.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old Yesterday, 01:55 PM
