How do these gears/sprockets look to you?
The intermediate shaft gear obviously needs to be replaced, but how do the rest of the gears look to you?
It's a 914 ...
Yeah the aluminum gear is definitely pitted on the teeth.
For the chain sprockets, can you catch a nail on any of the wear marks? Like on the side of the teeth. |
Try not, Do or Do not
The best way I have found to check chain sprockets is to lay a new chain on the sprocket and lift it in the middle. If you can lift the chain off the sprocket easily the sprocket is worn too much. What you are visually looking for is asymmetric wear in the sprocket trough wear the chain sit down in the sprocket.
The few shots you showed look pretty good.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-24-2025 at 06:14 PM.. |
PCA Member since 1988
Thats a gut-n-quick method for checking motorcycle chains too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
