Irrationally exuberant
ChrisBennet's Avatar
964 motor rebuild tools?
I'm starting to look for 964 rebuild tools and I was wondering if the tensioner tool (9401) is necessary or one of those tools nobody bothers with.
thanks,
Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-28-2003, 10:26 AM
PRO Motorsports
Tyson Schmidt's Avatar
Once you take it apart, it will be pretty obvious how to make your own tool for this. Just take a square piece of metal, drill two holes at opposite corners that are the same dimension as th tensioner housing, then drill and tap a center hole for a bolt to tension the rail.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 07-29-2003, 12:51 AM
Thanks Tyson. Now go to bed!
-Chris
Old 07-29-2003, 01:18 AM
