Irrationally exuberant
964 motor rebuild tools?
I'm starting to look for 964 rebuild tools and I was wondering if the tensioner tool (9401) is necessary or one of those tools nobody bothers with.
thanks, Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
PRO Motorsports
Once you take it apart, it will be pretty obvious how to make your own tool for this. Just take a square piece of metal, drill two holes at opposite corners that are the same dimension as th tensioner housing, then drill and tap a center hole for a bolt to tension the rail.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Thanks Tyson. Now go to bed!
-Chris
