In-car cam timing
Hey guys, can cam timing be checked in-car with the hydraulic tensioners keeping the tension, or do the chains have be held tighter than that? I want to re-check my cam timing but it's a real b#tch to remove the timing covers with thr turbos in place.
Mike 03 996tt w/efr7163 89 Carerra 3.6 |
I dunno how you will get a degree wheel on the crank with the engine in the car.
Degree wheel? I use a dial indicator.
Author of "101 Projects"
Yes, pretty easy to check the timing. Check the Engine Rebuild book or 101 Projects...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks for the reply Wayne, I know it's easy but I was just curious if the chain tensioners will kep the chain tight enough to get an accurate reading.
Thanks!
Mike,
My tensioners didn't keep the chains tight enough.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Thanks Dean, that's exactly what I needed to know.
Yes and no. It's safe to put extra tension on when measuring the cam timing...
-Wayne
Wouldn't you want to know what the timing is under the tension created by the tensioners since that's how it will operate in the car?
Gone 92 C2 82 Euro SC race car 993 C4S 3.8 84 Euro Carrera |
Air Medal or two
In real life the cams are being dragged /pulled by the crank as it rotates .So you will have to imagine that there is a pretty good resistance there...The only way to compensate for static timing is to make sure the "slack" side is real tight...this hopefully imitates whats going on in real life.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
I wouldn't worry about it - you just want to check to see if something is off, right? The tensioners have a pretty stout spring in them, and that is what does the pushing when you run the engine, not the oil.
I checked them and they are at 1.2 and 1.15 so I'm leaving them be. Now it's time to drive the snot out of it and get the rings seated.
