Party Member
viejopatron's Avatar
Cool 2,2 -> 2,4 Enhancement & Cams
Hi Kids,
I've decided to take the plunge. Upgrade the trusty, but anemic, 2,2 in my '71T to a 2,4. Using Wayne's "How to... ... Engines" as the primary guide, I'll stroke the engine with a 2,7 crank and go to the E cams. So's here my question...
It looks as if the timing values between a '71 T and E cam are significantly different. Possibly, a T could be re-manufactured into an E, however I'd like to hear from someone with experience on this option. Is this doable?
As always, the tradeoffs are reliability vs performance (vs cost).
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 09-01-2003, 03:52 PM
Author of "101 Projects"
Wayne 962's Avatar
Your camshafts will have to be rewelded and reconditioned anyways, so I'm not really sure of the question. Is the question really, "can I use my T cams as cores for the E cam regrind?" I'm not sure on that one - I would check with WebCam or Elgin...
-Wayne
Old 09-01-2003, 06:21 PM
Party Member
Good point. Actually, reconfiguring using the T's as cores is a better description. I do not want to recondition to T specs.
Gary
Old 09-01-2003, 08:39 PM
fancytown
Look into Tyson Schmidt's post on "scruffy" in the 911 Tech. Forum. You can likely use alot of your existing components, and have them machined, reconfigured, etc...into a really nice motor.
all cars sold.
Old 09-02-2003, 07:30 PM
Wayne 962's Avatar
On a side note, a 2.2T is a not a good engine to start with. Honestly, it's better to just put the T aside, and buy a core 2.7. That way, you will get the crank, rods, and 7R case that is stronger... Plus you get the heads, etc...
Core 2.7 long blocks are very commonly found at about $500...
-Wayne
Old 09-02-2003, 08:25 PM
canna change law physics
red-beard's Avatar
Are you saying to use the 2.7's case in the 2.2 to 2.4 upgrade?
James
Red-beard for President, 2020
Old 09-03-2003, 09:54 AM
Party Member
Red, I think Chairman Dempsey is suggesting More Power, i.e., why not spend the same effort and build a sporterized 2,7 engine. As Diablo runs pretty darn good, my hope was that the pistons could be overhauled, use E cams, decrease the flow restrictions, etc. and I could go from 125 hp to 165 hp. Anyway, thats the plan.
Jay, thanks for reminding me about Scruffy. I've now incorporated that thread into my Engine Notes.
Gary
Old 09-03-2003, 11:05 AM
