Luke Hudson's Avatar
How long does it take to rebuild and engine?
Hi Guys,
My lovely car just went in for a cylinder leak test and returned the following results:
Cylinder 1: 28
Cylinder 2: 22
Cylinder 3: 25
Cylinder 4: 26
Cylinder 5: 20
Cylinder 6: 18
So I have 3 options, 1)get a shop the rebuild it, 2) rebuild it myself or 3) sell it.
I've discounted option 1 on the basis of cost, so I'd like to know how long it would take approximately to strip the engine but NOT split the case and rebuild it from thier.
I have the technology and I have Wayne's book, but I don't have a lot of time, hopefully option 3 won't come into play!
Aubergine 1972 911 2.4E - Gone but not forgotton
HP2S #1185 - Ain't she purty
Resident @ www.ddk-online.com
Old 08-04-2003, 07:23 AM
HarryD's Avatar
Why do you need to rebuild?
Are there specific issues?
While not new specs, the results are not terrible.
Where are the leaks?
What is your compression?
You may be able to keep you car on the road and keep your money in your pocket for quite a while.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-04-2003, 07:38 AM
I would have the leakdown test redone by another shop. The numbers are too close in value; I would not have expected them to all go down simultaneously. I question if the procedure was done properly or if there was loose carbon keeping valves from seating.
Provided you have the parts on hand (you may need new pistons and cylinders), probably machine shop "turn around time" for the heads is the controlling factor. If this is not a factor, and you can apply yourself, the engine could be rebuilt in two weeks if nothing goes wrong.
Jim
Old 08-04-2003, 09:36 AM
Thanks Guys,
I'll get some more diagnostics done and re-read the book before I rip it apart.
The guy at the shop said it was leaking around the rings and the valves, he was all doom and gloom saying that if I leave it much longer it could be terminal!
What would I do without you guys? Spend a lot more money that's what!
Thanks!
Old 08-04-2003, 11:46 PM
Author of "101 Projects"
Wayne 962's Avatar
Well, as I mentioned in the book, your mechanic has a vested interest ($$$) in seeing you rebuild your engine. If need be, take it to a 2nd guy for an eval, letting him know that he's doing an eval only...
-Wayne
Old 08-05-2003, 01:26 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
And make the shop one that has no relationship with your original mechanic. People do talk...
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 08-05-2003, 08:47 AM
did the test get done when the engine was hot, so the rings are oiled? cold leakdowns are inaccurate. the engine also needs to be run after the plugs have been loosened a 1/2 turn, to blow out carbon bits loosened by plug removal, that might be sandwiched between valve and seat. any cylinders with high readings should be retested after running the engine again.
206 637 4071
Old 08-05-2003, 12:30 PM
I've just had the second test done, I stood over the guy when he did to ensure it was done correctly and got the folloing results:
Cylinder 1: 19
Cylinder 2: 21
Cylinder 3: 18
Cylinder 4: 21
Cylinder 5: 16
Cylinder 6: 15
All much nicer numbers! Looks like there's life in the old girl yet!
I plan to rebuild the engine enyway in a year or so, but now at least I have time to start saving for a rebuild and maybe S cams, new pistons, koni suspension, MSD, uprated brakes............
Thanks guys
Old 08-07-2003, 02:16 AM
Wayne,
oil is not being consumed at a noticeable rate (all leaks have been cured) and it doesn't seem to go down much at all.
I don't have compression figures at the moment
Old 08-07-2003, 04:09 AM
Thanks Wayne!
Old 08-07-2003, 05:21 AM
Just a quick update,
Compression test has been carried out and everything came out fine, cylinders were no more than 11% off the highest value.
Moral of the story, always get a second opinion, and ALWAYS read Wayne's book first!
Old 08-14-2003, 09:13 AM
Banned
snowman's Avatar
With numbers like you have and a shop telling you doom and gloom, RUN, don't walk, to another mechanic, and consider never going back to the first.
Unless you are racing it and are running first place most of the time you will never know the difference, its in 100ths of seconds per 2 mile lap. Sort of like changing engines every race.
Old 08-15-2003, 10:37 PM
Whatever you do...don't go to Motormeister for anything to do with anything regarding your engine. Simply put....i was drug through a knot hole and after 7 months am finally getting my engine put back together. Use a good local machine shop for all you machine work. Dissasembly and reassembly is really not very hard if you have the right tools. QUICK TIP...goto Sears and get the ratchet wrenches and the pivot head sockets. They are a must for a rebuild. And dont hessitate to spend the $75 or so for a cam holder tool.
ohhh yea!
Old 08-16-2003, 01:45 PM
Super Moderator
cstreit's Avatar
I'm not sure I'd go back to that shop to be honest with you...
For a non-case split rebuild, I've done it twice, can really get it done in a weekend, probably 25-30 hours of labor. This doesn't include machine work, etc.. which will add to the chronological time of the rebuild, but I see abso. no reason to dig into yours with those numbers.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-21-2003, 01:46 PM
Irrationally exuberant
ChrisBennet's Avatar
Re: How long does it take to rebuild and engine?
Originally posted by Luke Hudson
Hi Guys,
Cylinder 1: 28
Cylinder 2: 22
Cylinder 3: 25
Cylinder 4: 26
Cylinder 5: 20
Cylinder 6: 18
I'm gonna feel like an idiot for saying this (heck, I'm used to that); are these numbers % leakdown? And if they are, am I the only
one who thinks 28% leakdown is pretty bad? Please tell me you just left out the decimal points...
-Chris
You know that saying "There are no stupid questions"? Well we're going to make an exception in your case Chris.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-22-2003, 03:40 AM
bump
Old 08-22-2003, 11:07 AM
JOT MON ABBR OTH
I'm with Chris, I have a stupid question to ask....Uhm, please see Chris' post...
Old 08-22-2003, 02:32 PM
