Case squirters blocked, removal.
Please could anyone help .. I have not forund this information in wayne's book, nor in Bruce's...
I have a 2.4 case but one squirter is blocked with something. I need to remove it and clean or replace it. It would be easy to punch out but it is in the Wrong Case Side! Please help before I get mad with it! PS Do you sell squiteres please, Wayne? Kind regards David |
This is the procedure from the factory 993 manual, the 2.4 should be similar
Thanks Guys!..
I got it out with the 5mm tap. and there was silicon blocking it! I am quite surprised than no-one seems to know what angles and dimensions are needed to drill the squirter holes! Kind regards David |
