canna change law physics
If it smokes when...
Does someone have a chart setup to help diagnose what is wrong with an engine based on when/how it smokes?
It was smoking a bit on startup. Then it started smoking when turning/banking to the left. Now it's smoking a small amount under accelleration, but loads under heavy decel. I also seem to be getting a bit of blow by. Rings? Guides? Compression test will be next, in a couple of days. This is originally a 2.0T type engine (914/6) upgraded to 2.2 with either E or S cams (PO is not sure). The smoking and blowby became much worse when I recently replaced the leaking rear main seal. James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Warren Hall Student
Smoking from heavy decel is usually worn valve guides. Oil gets sucked into the chamber threw the guides upon decel.
The smoke on startup also can be caused by worn guides.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Author of "101 Projects"
Run a leakdown test, and you should be able to hear where it's coming from (valves or rings, left or right)...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
