Broke an Oil Ring Installing
I broke an oil ring installing it on the piston. Is there any where I could get a single piston set of rings. I have the old rings and could use them in a pinch. Any thoughts? BTW It is for a 3.2l Carrera motor.
Thanks, Arnie |
Who did you buy the rings from?
Most places I know will not break up a set of rings to sell one. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Danke
Thanks for your reply, I found the same issue. I spoke with my machinist and was told that intalling one old oil ring wouldn't be a problem, so I picked my best one and moved on...
Thanks, Arnie AFJuvat... I agree fully with your closing... |
Author of "101 Projects"
Yikes, your machinist was kidding right? Cutting corners like this on a 911 engine rebuild? I don't think any of the machine shops I know of would recommend using an old, used part in a $8K rebuild - it's just not worth it, and it's just not done.
I think we can get you a single set of rings if you need them... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I had this same problem a few weeks ago and was able to buy one set of rings from ProTechnik in Houston.
Wayne, I would imagine this happens often enough to warrant selling individual sets of rings.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Same thing just happened to me here!
I called and the customer service guy at Pelican Parts and they said they dont break up sets. ![]() Does anyone else know where I might be able to get 1 set of GOETZE rings (95mm-1.5 X 1.75 X 4.0mm), for a '78SC? |
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 05-10-2004 at 03:24 PM.. |
Yes, we can sell individual rings, give Tom a call at 1-888-280-7799x221 and he can special order these for you. I'm having Eugene add these to the catalog too...
-Wayne
