What's This Notch For?
Can someone explain what this notch in my engine case is for. It seems that it was filled up with the case sealant. Does this matter or should I avoid this when I reseal the case?
Irrationally exuberant
Re: What's This Notch For?
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thanks Chris!
I knew it was there for a reason. |
so how in the hell do you get enough sealer on there so the case doesn't leak externally, and not get the sealer in the groove? and how do you know if any got in there? personally, i don't think it matters. that's also an area of the case which is prone to leak-thru to the outside if you don't get enough sealer between the halves. 574 might work, but there's no air in the groove with the cases bolted together, and i bet it would harden just fine.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 09-25-2003 at 01:16 PM.. |
Nope, the 574 will not harden Only times I have seen that groove blocked is when a sealant other than 574 was used.
Also IMHO, people use entirely too much sealant on the case - just enough 574 so you see it on the surface of both case halves is plenty. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Author of "101 Projects"
There is much discussion on this topic of case sealant. The beauty of 574 is that it will only harden in the absense of oxygen, so if you get any in these grooves, the oil will simply wash it away. At least that's the stock answer. Other sealants (like the Dow Corning) - you need to be a bit more careful, and only use a thin bead.
Check out the engine book for details on how much 574 to use... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
These are a few shots of the passage from my 3.0 case. Ive picked some of the excess out already but you can still see that whatever it was that the factory used didnt wash out very well.
So do you guys recomend that when I put her back together that I put sealant on the inner surface area of the cutout or only to the outer side? I was also wondering if the 574 is OK to use if the motor is going to sit for awhile as it wont have any oil (to wash it out) in it for a month or two after I seal the case. ![]()
Super Moderator
Simon,
I would imagine it's okay. It sits in the bottle without hardening for months...
