Warren Hall Student
Replacing sprockets on intermediate gear
Hi guys,
I'm having a tough time replacing the chain sprockets on my intermediate shaft as in I can't get the old ones off. And yes, I have removed the circlips. I tried the blue wrench but that hasn't work. What do you guys use? A steering wheel puller? I was hoping I wouldn't have to buy one just to remove these sprockets.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Bobby,
I belive Dave had to press them off at his local mechanics and then he used an oil bath to heat up the new ones and they droped right on.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Irrationally exuberant
I know I've removed them with a gear puller (3 arm) and no heat. I may have used a press the last time (can't remember).
Use a heat gun to warm them up before dropping them on the (cool) shaft. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Warren Hall Student
Thanks guys,
I think the gear puller sounds like a good option. I'll just take the shaft over to a tranny shop.
i use the press.
Author of "101 Projects"
Gear puller / press is a good option, but most people don't have the tools to do this properly. Simply have your machine shop take it apart for you...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
