Slumlord
Porsche_monkey's Avatar
Piston Squirter Cleaning - 4/5/6
I've read several posts on cleaning the piston squirters but I am still totally lost.
Where do you plug the gallery? I've plugged both ends on all through bolts, do I need to plug the port beside the oil thermostat and the two ports perpendicular to that?
Like I said I'm lost, (and Waynes book is very sketchy in this area).
Any one got a better description that even an utter moron could comprehend?
Old 10-29-2003, 10:31 AM
Pat S's Avatar
Take a look here:
AAARG! Stupid Piston Squirters!!!!
I basically took an old fuel line, wrapped it in electrical tape to make a real good seal, Plugged up the through bolt hole, then shot cleaner from the bearing journals holes under high pressure.
Pat
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 10-29-2003, 11:07 AM
Slumlord
Maybe I'm not sealing far enough into the bolt hole? That would leave me connected to the gallery, which I should be blocking off with a longer plug?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 10-29-2003, 11:31 AM
Slumlord
I pushed my 'plug' in much further, ie far enough to block off the gallery. Now I can blow air through the squirter.
84 Cab - sold!
Old 10-29-2003, 01:58 PM
