Head Studs Q...
I'm currently rebuilding my engine and was suggested to use Carillo head studs. I never heard of Carillo head studs before but I've heard Carillo forged connecting rods. None of the current stock studs are damaged and I was going to replace them with ARP. Any info if the Carillo's exists and if they did, how would they compare to ARP or Raceware? Or should I approach the "If it ain't broke, why fix it"?
John 1997 993 2012 991 |
Irrationally exuberant
I've never heard of Carillo head studs either. Maybe whomever suggested them was thinking of ARP or Raceware?
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Super Moderator
They probably got confused...
Raceware or ARP are nice, but I believe them to be overkill for street engines... Why not just use the steel 993 studs? (Or are you building a monstor motor or something?)
Chris,
I'm not building a monster motor but I will be using this as a street / track car.
Senior Member
Use factory steel studs. They're the cheapest and perfectly reliable.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
