Tach not working
'72 911T with '67 911 engine. I have a Perma-Tune and a Bosch Blue coil, but the tach has never worked, 11 years owned, I'm just starting to do my own maintainence and I want to get this tach working! Where can I begin looking? Thank you for the time.
Frank in Naples, FL
1972 911T
1983 944
Old 11-25-2003, 05:45 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Is there NO input into your tach or is it bouncing around and giving eroneous readings?
The first thing I'd do would make sure the purple/black wire is plugged in by your distributor.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 11-25-2003, 06:03 AM
Friend of Warren
Is the tach wire in the engine compartment hooked up? Should be a purple/black wire.
Kurt V
Old 11-25-2003, 06:04 AM
I will look for the purple/black wire connected to the distributor. There currently is NO input into the tach, it is not bouncing or giving erroneous readings
Frank in Naples, FL
1972 911T
1983 944
Old 11-25-2003, 04:14 PM
Thumbs up
The purple/black wire is connected to the dist. cap, then the wire runs, with a bundle of other wires, to the left side of the engine compartment and it plugs into a connector, then I wonder what
Frank in Naples, FL
1972 911T
1983 944
Old 11-25-2003, 05:39 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
I think it may actually start it's run from the negative side of the coil....
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 11-25-2003, 08:46 PM
83 911 tach
hey Tim my name is GAry I have 83 sc my tach does just that jumps around with bogus reading and sometimes operates fine any ideas??
Old 11-20-2009, 07:44 AM
tach
The SC tach is a magnetic triggered style, you may have to back date the tach or use an MSD box instead of the permatune.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 11-20-2009, 08:19 AM
There is a different electrical connection to the tach for the different model years.
It is indeed a black/purple wire. On CDI cars up to 2.7 with 3 connections at the CDI unit, it is connected under the relay plate in the engine compartment. Hard to locate.
On cars with 6-connection CDI units, it is connected via the 14-pin connector at the back of the relay plate, thus needs to be reconnected.
Maybe after changing to the Permtune, the connection has been "forgotten"...
jens
Old 11-28-2009, 07:52 AM
