Tach not working
'72 911T with '67 911 engine. I have a Perma-Tune and a Bosch Blue coil, but the tach has never worked, 11 years owned, I'm just starting to do my own maintainence and I want to get this tach working! Where can I begin looking? Thank you for the time.
Frank in Naples, FL 1972 911T 1983 944 |
Is there NO input into your tach or is it bouncing around and giving eroneous readings?
The first thing I'd do would make sure the purple/black wire is plugged in by your distributor.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Friend of Warren
Is the tach wire in the engine compartment hooked up? Should be a purple/black wire.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I will look for the purple/black wire connected to the distributor. There currently is NO input into the tach, it is not bouncing or giving erroneous readings
The purple/black wire is connected to the dist. cap, then the wire runs, with a bundle of other wires, to the left side of the engine compartment and it plugs into a connector, then I wonder what
Unoffended by naked girls
I think it may actually start it's run from the negative side of the coil....
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
83 911 tach
hey Tim my name is GAry I have 83 sc my tach does just that jumps around with bogus reading and sometimes operates fine any ideas??
Thanks |
tach
The SC tach is a magnetic triggered style, you may have to back date the tach or use an MSD box instead of the permatune.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
There is a different electrical connection to the tach for the different model years.
It is indeed a black/purple wire. On CDI cars up to 2.7 with 3 connections at the CDI unit, it is connected under the relay plate in the engine compartment. Hard to locate. On cars with 6-connection CDI units, it is connected via the 14-pin connector at the back of the relay plate, thus needs to be reconnected. Maybe after changing to the Permtune, the connection has been "forgotten"... jens |
