Author of "101 Projects"
A hotter cam would probably give more power, but I want to keep the engine's power band pretty uniform (less peaky). The 'S' cam on the 3.2 is a well-proven combination that gives plenty of low-end torque. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Cost effective? Probably about the same as the other methods, but you can control timing, and you never have to buy distributor caps again. Plus, the system has a good resale value on the market. I have an extra one used, if anyone is interested. I think I want $850 for it (it's an earlier model HPV system). -Wayne
The JEs are a fine alternative, and can be very reliable too. Also, they are significantly less expensive when doing a rebuild. -Wayne
As an aside, I got both the 101 projects and the Engine Rebuild book in the mail yesterday, they're great. Nice job on the info, layout, and look. JCM
Stuff of marginal consequence: - 1974 911"Carerra" sunroof coupe |
Hilbilly Deluxe
Tom |
Thanks Tom I forgot about that. Better refigure my Budget.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Now when they bore out the 95's to 98 do the need to replate?
Dennis H. 72 911E 2.7 RS stuff 72 911T with a 2.7(Sold 5-13-2011) 2012 Kona Blue Metallic Mustang GT Convertible 6spd 67 Mustang coupe future SVRA group 6 car 63 Falcon hardtop 302/4spd |
Irrationally exuberant
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I have a 3.0 SC twin plug engine with 10.2 comp., ported heads, RSR cams, 46mm Webers, and Electomotive XDI twin plug ignition, 1 5/8 headers with megaphones. Any idea of what kind of power increase I would see by just swapping to 10.5 comp. 98 mm pistons and cylinders to make it a 3.2 short stroke? Are the 98mm cylinders slip in or do the require the case spigots to be bored?
Joe 996 GT3 RSR Last edited by jacko241; 06-12-2005 at 07:20 AM.. |
Jacko, how high do you rev this engine, and what kind of fuel are you running?
John Dougherty Dougherty Racing Cams |
John, it is in a dedicated race car, and I am shifting at 7400 rpm. I am running 112 Sunoco leaded racing fuel.
Joe 996 GT3 RSR |
I would increase the compression ratio up to 12-1 at least. with the type of fuel you are using you will have no problems and you will get a nice increase in torque and HP. I would also run the car on a chassis dyno with the combination you have now with the 112 fuel. I would also try some 100 or 104 octane. You should see a small increase in power with the lower octane fuel. With 10.2-1 and twin plugs the engine will be fine on 100 octane.
Yes, I want to run it on the dyno, but it hasn't been in the budget. I always worry about reliability when increasing compression ratio.
Joe 996 GT3 RSR |
