Cold start sputter. 3.0
my 3.0 sputters caughs and pops for the first 15-20 secconds on startup when cold. Then smoothes out to a nice clean idle...also getting some white smoke puff at startup too. Recent rebiult 1500 miles ago and has been doing this since i installed motor.
Have new WUR, new Cold start valve, new plugs, new wires, etc etc. Any suggestions?
ohhh yea! |
Have you checked your system and control pressures? If the WUR is new, it might need to have the plug knocked in a bit, which will allow for a lower control pressure during cold start and in turn a richer mixture. I think, from what I have read your mixture needs to be set properly before you adjust the WUR. Still learnig myself though....
R/ Dustin |
HMM interesting, ok ill check it out.
ohhh yea! |
