Friend of Warren
Trying to Time Cams, What the Hell Did I Order?
My screw up, I should have checked the tools I got in instead of completely relying on the rebuild Wizard. With the Wizard set to the 3.2 Carrera when you check the box for the Z block for the dial indicator it doesn't load the part number for the Z block (P207). What it does load is P240 which is listed as a dial gauge holder and looks like this:
Question abput the photo below, is the extension that comes with the Z block screwed onto the shaft of the dial indicator to make the shaft long enough to reach the valve stem collar? If not, there is no way the dial indicator that I received is going to have a long enough shaft to reach the valve collar.
Kurt V
Old 01-02-2004, 12:37 PM
Senior Member
Superman's Avatar
The bottom pic is the Z-block you need. I don't recall whether the dial indicator extension is needed, but probably. My dial indicator came with the extension.
Mocha 1978 911SC. "Coco"
Old 01-02-2004, 01:19 PM
anyway, the extension is required.
206 637 4071
Old 01-02-2004, 03:18 PM
Super Moderator
cstreit's Avatar
I made a block for 15 cents from some scrap.... Got a welder?
Highlighted in this picture in red...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-03-2004, 12:00 PM
