Friend of Warren
Trying to Time Cams, What the Hell Did I Order?
My screw up, I should have checked the tools I got in instead of completely relying on the rebuild Wizard. With the Wizard set to the 3.2 Carrera when you check the box for the Z block for the dial indicator it doesn't load the part number for the Z block (P207). What it does load is P240 which is listed as a dial gauge holder and looks like this:
Question abput the photo below, is the extension that comes with the Z block screwed onto the shaft of the dial indicator to make the shaft long enough to reach the valve stem collar? If not, there is no way the dial indicator that I received is going to have a long enough shaft to reach the valve collar.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Senior Member
The bottom pic is the Z-block you need. I don't recall whether the dial indicator extension is needed, but probably. My dial indicator came with the extension.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
anyway, the extension is required.
Author of "101 Projects"
Hmm, I'll have to check that out. You don't always need the extension if you have a universal gauge holder and some ingenuity. See 101 Projects (cam timing) for a picture...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Super Moderator
I made a block for 15 cents from some scrap.... Got a welder?
Highlighted in this picture in red...
