Case Washers
Hi
What sort of washer are on the Nyloc Nuts around the case?
The part no I can only guess is 900 031 014 30 (from the
ones that hold the cam chain boxes on, They are not shown on
the crankcase diag on PET), but are the just a flat 8mm steel
washers?
Neven
Old 01-18-2004, 04:47 PM
dtw dtw is offline
GAFB
8mm aluminum crush washers
Several BMWs
Old 01-18-2004, 05:19 PM
Thanks, Do you know the dimensions or of an alternative supply to porsche as 12c each.
Neven
73 911E, 70 914/6
Old 01-18-2004, 09:54 PM
Author of "101 Projects"
Wayne 962's Avatar
We sell packs of these in our rebuild section:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_enginR_pg2.htm#item6
You can also use the ones from a gasket kit that includes the hardware.
-Wayne
Old 01-19-2004, 02:29 PM
Wayne
I called Wurth here in NZ, they have 8x14x1.5 are
these OK
Neven
Old 01-19-2004, 02:35 PM
davidl's Avatar
Hello ythere.
No they are not aluminium.. they are magnesium alloy and much harder than the usual Al. available.
If you use Al, they will crush after install and you will likley get leaks..
Kind regards
Old 01-20-2004, 12:13 PM
