2.4 Stroker Engine from a 2.2 ?
I have seen ads as well as postings for "2.4 Stroker engine" where a 2.2 case used in conjunction with at 2.4/2.7 crank and then the 2.4/2.7 rods as well. What are the issues with this setup or rather what needs to be done to make this a "reliable" engine.
Old 01-18-2004, 06:41 PM
jluetjen's Avatar
As far as I know it isn't much different then the stock 2.4. There may be some differences in regards to case version and stuff. But if done right I doubt that the performance would be any different then a stock 2.4.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-19-2004, 04:36 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
That's what the factory did to get 2.4 liters...
Scott Kinder
kindersport @ gmail.com
Old 01-19-2004, 10:32 AM
Wayne, I saw that engine configuration recommended in a section of your book using E pistons and E cams with 40 webers. Is it fair to say the output would be similar to a stock 2.4E or does the increase in compression buy you more performance? The compression increase seems small.
"Rust never sleeps"
Old 01-20-2004, 11:43 AM
