Send a message via Yahoo to Groovy911SC
911 SC head recondition question
After chatting with my friendly machine shop tech concerning the reconditioning of my heads, he suggested using firmer springs from Jerry Woods Enterprises. These springs offer protection from a possible over rev not exceeding 9000 rpm or there abouts.
Has anyone gone this direction? His advice seems acceptable to me. There would be an additional charge of around $300.00 which I would gladly pay for a bit of additional insurance to protect my engine from the novice driver of the car( Me!).
Any advice or stories would be appreciated!
Old 02-11-2004, 07:05 AM
Senior Member
Superman's Avatar
Yep, it's common for folks to install stiffer springs. If I did that, I'd also want to use Ti retainers.
Mocha 1978 911SC. "Coco"
Old 02-11-2004, 07:30 AM
Senior Member
Doug Zielke's Avatar
Building a race engine?
If not, stock springs are perfectly good, sez the pro who re & re'd my 3.0 heads.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 02-11-2004, 03:34 PM
Larry Harris's Avatar
It will put more pressure on the cam geometry and associated parts.
2001 Turbo
Old 02-11-2004, 05:31 PM
Irrationally exuberant
ChrisBennet's Avatar
For the street where you never miss a shift, stock is fine.
For the track, where um "accidents" do happen, stiffer valve springs and light weight retainers make a missed shift an "ooops" vs a bunch of bent valves and a trailer ride home.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-11-2004, 07:49 PM
Thanks Chris! I will track the car in DE events. I know I will miss shifts while learning. I've already had to trailor the car back home once due to mech failue. With more track time scheduled, I'd like to have a bit of insurance.
In time, I want to race PCA. My goal is to build that car in a couple of years! This rebuild, is meant to get me back on the road for pure Porsche driving pleasure and to learn more on the track!
1980 911SC
One day will be "G" Stock PCA racer
Old 02-12-2004, 07:34 AM
Another option is to get new stock springs. I'm told they get weak over time. When I rebuilt my engine I found a mark from the intake valve on top of 2 pistons. Although I'm not racing now, I approach 6k often enough to want to make sure. I replaced my springs and valves.
$108 here on pelican for new springs. 1/3 of the cost of the race ones.
Just another option / opinion.
What are you doing about rod bolts?
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 02-12-2004, 10:43 AM
William, I will use stock rod bolts. I feel that going with ARP or Raceware would be over kill for this re-build. If adding race type springs will create addition stresses on other components I may be causing problems else where. I wonder if I use the Jerry Woods springs valve springs, which components I would have to consider upgrading?
1980 911SC
Old 02-12-2004, 12:41 PM
The SC's rod bolts are plenty strong. The rod bolts become an issue with the later cars that had 9mm instead of 10mm rod bolts. The stiffer springs will make the rockert press on the cams a little harder.
-Chris
Old 02-12-2004, 01:25 PM
